Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
lots of input errors,help me
gsr ios:12.0.31S5
module: 2 Port ES Packet Over SONET OC-192c/STM-64
question: show interface
MTU 4470 bytes, BW 9952000 Kbit, DLY 100 usec, rely 255/255, load 83/255
Encapsulation HDLC, crc 32, loopback not set
Keepalive set (10 sec)
Scramble enabled
Last input 00:00:01, output 00:00:01, output hang never
Last clearing of "show interface" counters 00:41:24
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 2810144000 bits/sec, 671994 packets/sec
5 minute output rate 3270123000 bits/sec, 852785 packets/sec
1668857620 packets input, 871705121205 bytes, 0 no buffer
Received 0 broadcasts, 518849 runts, 0 giants, 0 throttles
0 parity
631850 input errors, 112908 CRC, 0 frame, 0 overrun, 0 ignored, 93 abort
2108674120 packets output, 1016826523728 bytes, 0 underruns
0 output errors, 0 applique, 0 interface resets
0 carrier transitions
1 REPLY
Re: lots of input errors,help me
You have a lots of input errors that denotes that its is a physical layer issue. You have to try replacing the cable connected to the port and talk to your TELCO as it might be a problem at their end. In most of the cases its the TELCO problem and You need to have the carrier do an end-to-end loopback test.
HTH, Please rate if it does.
-amit singh
112
