Low latency queueing -- best practices/limitations
I recall reading or hearing somewhere that there was a practical restriction, or at least a best practice, regarding priority queueing for voice across WAN links.
I thought that you cannot, or should not, build QOS parameters to allocate >20% of the WAN bandwidth to voice traffic. I thought it was a limitation on the low-latency queueing buffers or something. Now, of course, I can't find any documentation to that effect.
So here's the question: is there a hard limit or a best practice limitation on how much bandwidth you should allocate to the voice priority queue?
1 REPLY
Re: Low latency queueing -- best practices/limitations
Cisco Technical Marketing testing has shown a significant decrease in data application response times
when realtime traffic exceeds one-third of link bandwidth capacity. Extensive testing and customer
deployments have shown that a general best queuing practice is to limit the amount of strict priority
queuing to 33 percent of link capacity. This strict priority queuing rule is a conservative and safe design
ratio for merging realtime applications with data applications.
Hope that helps
Chris
Check out the SRND guides
109
