M1T-T3 pa/Cisco 3825 Capatibility
Simple question: Will a M1T-T3 pa module work in a 3825 router? Please advise...
Chris
1 ACCEPTED SOLUTION
Re: M1T-T3 pa/Cisco 3825 Capatibility
No, this is a PA (Port Adapter), the PA support the Cisco 7200 series routers as well as VIP based Cisco 7000/7500 series routers.
HTH,
Mohammed Mahmoud.
HTH,
Mohammed Mahmoud.
If you want a T3 module for a 38xx series routers, you can go for a NM-1T3/E3
Narayan
Just one more view to Mohd.'s point, any module which is a PA is by default 7200 Router Module.
Secondly, the DS-3 Module can come under two implementation i.e. ATM or Serial, depending upon the Service required / availability you should be bit careful regarding the correct part number.
However with respect to the NM T-3 Module there is no complication its available in Serial mode only (though support for ATM DXI exists)
Datasheet for the ATM NM
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a008010fba2.html
Please visit the PA-T3 Serial Datsheet:
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_data_sheet09186a00800a3e07.html
And to know bit more about PA-A3 or ATM based PA, please visit the PA-A3 Datasheet
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_data_sheet09186a0080091d75.html
Hope that helps,
Kind Regards,
Wilson Samuel
331
