MAC filtering in a Catalyst 2960 ?
MathiasTh
Hi all !
I have the opportunity to buy either a Catalyst 2960 WS-C2960-24-S or a WS-C2960-24TC-S.
Does any of these two models support simple MAC-fitering, just as can be found in simple home routers (allow/deny lists) ?
I just want to allow one specific MAC address per port, and also a list of denied MAC addresses for ports that are not locked to a specific MAC.
Cheers & TIA !
/Mathias
Collin Clark
Both switches can allow a single MAC. It uses port security and there are a myriad of options to configure. Logged MACs would show up in the logs/syslog of the switch. Check the link for additional info.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_46_se/configuration/guide/swtrafc.html#wp1038501
Hope it helps.
Collin Clark
Hope it helps.
Excellent !
Thanks for the fast reply Collin.
Cheers !
/Mathias
