MAC Flap Notifications from Wireless Clients
Hello everyone!
I'm getting MAC flap notifications from 2 switches at our remote office from the same two switches (switch 2 & 6).  There are a total of 7 switches (5 on the first floor & 2 on the second floor).  Each switch connects to the root bridge with no redundant links.  There are 4 access points that are autonomous with two SSIDs; 2 of the APs are connected to switch 2 (1st floor) and the remaining two are connected to switch 6 (second floor).  The switchport configuration is as follows which is the same at our main campus:
interface GigabitEthernet1/0/1
description *** WIRELESS ACCESS POINT ***
switchport mode trunk
switchport nonegotiate
speed 100
duplex full
macro description cisco-wireless
spanning-tree bpduguard enable
end
At the main campus we have a 5508 WLC with 85 LAPs and we don't have this issue.  My assumption at this point has to do with roaming since our therapists have to move between both floors.  What's even strange is that I can't find the mac (0013.0210.5344) of the device causing the flaps when I run the command 'show dot11 assoc' from my APs.  All I know based off the MAC is that it's an Intel WNIC.  Here is the config of one of the APs at the remote office.  How can I get to the bottom of resolving these MAC flapping notifications?
version 12.4
no service pad
service password-encryption
hostname pag1ap01
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone -0500 -5
clock summer-time -0400 recurring
ip domain name <DOMAIN>
ip name-server <DNS IP>
dot11 vlan-name default vlan 1
dot11 vlan-name dsl vlan 6
dot11 ssid pathwaysaironet
   vlan 1
   authentication open
dot11 ssid patnet
   vlan 6
   authentication open
   guest-mode
dot11 network-map
power inline negotiation injector 001a.6c7c.4882
power inline negotiation prestandard source
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 6 key 1 size 40bit <KEY> transmit-key
encryption vlan 6 mode wep mandatory
encryption vlan 1 key 1 size 128bit <KEY> transmit-key
encryption vlan 1 mode wep mandatory
ssid patnet
speed  basic-1.0 basic-2.0 basic-5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.6
encapsulation dot1Q 6
no ip route-cache
bridge-group 6
bridge-group 6 subscriber-loop-control
bridge-group 6 block-unknown-source
no bridge-group 6 source-learning
no bridge-group 6 unicast-flooding
bridge-group 6 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
speed 100
full-duplex
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.6
no ip route-cache
bridge-group 6
interface BVI1
ip address <IP ADDRESS> <MASK>
no ip route-cache
ip default-gateway <GATEWAY IP>
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community snmpsux RO
bridge 1 route ip
line con 0
line vty 0 4
sntp server <SNTP IP>
sntp broadcast client
end
Yes, we're not using the most secure encryption on the wireless and that'll be changed but I need to resolve the flapping issue first.  You're help is greatly appreciated.  Thanks!
Terence
167
