Manipulate BGP AS path
rknutsen
I need to remove an AS # in the path before passing the route on to our provider. I know the "set as-path prepend" command can add AS #s to the path, but is there a way to remove the current AS# before sending it on to our provider.
Example.
Router is learning routes from router in AS 65100. Need to pass these route to provider, but they will only accept routes with AS 65417 in the path.
These commands prepended 64517, but path still contained 65100 in it.
router bgp 64517
neighbor 1.2.3.4 route-map prepend-routes out
route-map prepend-routes permit 10
set as-path prepend 64517 64517 64517
rais
Level 7
Level 7
You can use: neighbor a.b.c.d remove-private-as.
I dont think the ASN for router peering with ISP will be removed.
Thanks.
rais
Level 7
Level 7
Thanks.
Use the following command
router bgp 64517
neighbor 1.2.3.4 remove-private-AS
regards
Narayan
I tested "remove-private-as" on our Internet router and it did the trick. It removed our internal ASN of 65100, but still kept 64517.
Thanks for the help.
Richard,
The fact that 64517 is still there is normal behavior as IOS applies the remove-private-AS before it inserts the local AS and prepends additional ASes.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
