mark policy w/ trust dscp
jhancoc
I have a 7604 as a WAN router. I need to use a service policy to mark dscp based on a subnet address using an ACL. In addition to this service policy, I also need to honor dscp markings from things like IP Phones. It appears that its improper to use a service policy input on an interface to set dscp while also using the mls qos trust dscp command on the same interface.
Is there a workaround for something like this, on the same router?
jhancoc
I think I just solved my own issue. Can someone please verify this? From what I can tell, having a service policy input on an interface assumes mls qos trust dscp. Is this true, and if possible can someone link the documentation to this effect?
Rupesh Kashyap
The logic is same like-
1. Create ACL for the source and destinatiion
2. Create Class Map and match the ACL
3. Create Policy Map and add Class-map in that. Set Voice as DSCP EF or AF41.
4. Bind the Policy Map with interface.
jhancoc
I know how to set a service policy to mark dscp. My question is in regards to using a policy map to mark DSCP, while also using the mls qos trust dscp command. The mls qos trust dscp command appears to disable the ability for a service policy to mark dscp while configured on the same interface.
