Marking FE traffic for QOS process
locus2007
Hallo,
I need mark traffic from specific FE switch port on C1802 when in goes thrue Dialer there is done some Qos process.
How can I do this on FE 8 if all ports are in BVI1?
I tryed IP based marking that is not good in case of DHCP clinets off course.
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Vlan1
  no ip address
  bridge-group 1
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip address 192.168.X.X 255.255.255.0
no ip redirects
no ip unreachables
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly
zone-member security in-zone
ip tcp adjust-mss 1452
bridge 1 protocol ieee
bridge 1 route ip
Urbanek
Giuseppe Larosa
Hello Mark,
you may only approximate this with an extended ACL that matches source ip address of device connected to Fas8 and then you apply a policy-map inbound on BVI interface
Hope to help
Giuseppe
17 Replies 17
Giuseppe Larosa
Hello Mark,
Hope to help
Giuseppe
Thanks, I have on mind to mark all trafic from FE8 -> DSCP er, and then I will after NAT on Dialer make policy-map to search for DSCP er and give bulk.
Yes there is no posibility to mark Ethernet port as origin of traffic. So must be done on IP address or protocol.
You can create policy-map and attach this policy-map to the FE 8 interface
policy-map DSCP-EF
class class-default
set dscp ef
interface fastethernet 8
service-policy input DSCP-EF
You can change the DSCP marking to the intended one in your configuration.
Edison
Thanks I tryed this
look - I have it on FE6 now I know, for testing only on FE6 is my testing notebook that generate traffic
class-map match-any Dialer1_out
match  dscp ef
class-map match-any class_local_FE8_mark
match access-group name Rule_local_FE8_mark
policy-map CCP-QoS-Policy-1
class Dialer1_out
    priority percent 33
class Dialer1_out
    priority percent 33
policy-map policy_local_FE8_mark
class class_local_FE8_mark
  set dscp ef
service-policy input policy_local_FE8_mark
interface Dialer1
description $FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
ip mtu 1492
ip flow ingress
ip flow egress
ip nat outside
zone-member security out-zone
encapsulation ppp
dialer pool 2
dialer-group 2
ppp authentication chap pap callin
ppp chap hostname X
ppp chap password 0 X
ppp pap sent-username X password 0 X
no cdp enable
service-policy output CCP-QoS-Policy-1
ip access-list extended Rule_local_FE8_mark
remark CCP_ACL Category=256
permit ip any any
but all trafic is in class-default and not in Dialer1_out class
If I understand you correctly, you want to mark all traffic entering switchport FE 8 to a certain DSCP value.
I recommended to use the class class-default on a policy-map but I don't see that in your configuration.
You are matching on ip protocol, this won't work.
Please try the config I posted before and once you do, generate traffic that enters FE 8 and post the show policy-map interface output.
Edison.
Yes based on your recomend now I got
policy-map DSCP_EF
class class-default
  set dscp ef
service-policy input DSCP_EF
service-policy output DSCP_EF
Router#show policy-map interface output
FastEthernet6
  Service-policy output: DSCP_EF
    Class-map: class-default (match-any)
      232 packets, 13920 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: any
      QoS Set
        dscp ef
          Packets marked 0
Now i get that packets on class-default on port FE6 there is ping command
Now are packets marked with ef?
So I can make other policy on dialer to look for EF and then make qos?
I recommend to mark on input, yet you applied the service-policy on input and output direction.
Your 'show policy-map interface' only includes the output from the 'service-policy output', I need to see the 'service-policy input' as well - that's where packets must be marked.
If you noticed in the output
QoS Set
        dscp ef
          Packets marked 0
No packets were marked while leaving the port, the intention is to mark packets as they enter the port.
What I need from you is to remove the 'service-policy output' from FE6 and post back with the 'show policy-map interface' with only the input policy-map applied.
Edison.
Thank you that you spend time with this.
policy-map DSCP_EF
class class-default
  set dscp ef
ping command still goes and I tried also come TCP traffic (WWW browsing)
FastEthernet6
  Service-policy input: DSCP_EF
      0 packets, 0 bytes
      Match: any
      QoS Set
        dscp ef
          Packets marked 0
I noticed packets marked 0 after sending last reply.
And you are sure traffic is entering FE 6?
Clear the counters and post the output from typing 'show interface f6' and 'show policy-map interface'
Edison
I look at http://www.cisco.com/en/US/partner/docs/ios/qos/configuration/guide/mrkg_netwk_traffic_ps10591_TSD_Products_Configuration_Guide_Chapter.html
and didn't  found nothing wrong.
IOS 15.0.1M
Router#clear counters fastEthernet 6
Clear "show interface" counters on this interface [confirm]
Router#show interfaces fastEthernet 6
FastEthernet6 is up, line protocol is up
  Hardware is FastEthernet, address is 0021.5556.35d5 (bia 0021.5556.35d5)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:00:37
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1000 bits/sec, 2 packets/sec
  5 minute output rate 2000 bits/sec, 3 packets/sec
     75 packets input, 5836 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     111 packets output, 8830 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
And it increase.
  Last clearing of "show interface" counters 00:00:39
  5 minute output rate 1000 bits/sec, 2 packets/sec
     79 packets input, 6148 bytes, 0 no buffer
     116 packets output, 9206 bytes, 0 underruns
Router#
And still same.
FastEthernet6
      0 packets, 0 bytes
      Match: any
      QoS Set
        dscp ef
          Packets marked 0
Is not problem in BVI1 ?
I think the problem is that Fas6 is a port of an etherswitch module in an ISR router.
Probably QoS features are not supported on Etherswitch ports.
let's see the restrictions section of the link you have provided:
Traffic marking can be configured on an interface, a subinterface, or an ATM permanent virtual circuit (PVC). Marking network traffic is not supported on the following interfaces:
Any interface that does not support CEF
ATM switched virtual circuit (SVC)
Fast EtherChannel
PRI
Tunnel
Fas6 should be a L2 only port  that does not support CEF.
Hope to help
Giuseppe
It looks real, all I can find is
10/100 LAN Switch
Eight 10/100BASE-T fully managed switch ports with 802.1Q VLAN and 802.3af PoE support
