11-25-2009 04:52 AM - edited 03-04-2019 06:47 AM
Hallo,
I need mark traffic from specific FE switch port on C1802 when in goes thrue Dialer there is done some Qos process.
How can I do this on FE 8 if all ports are in BVI1?
I tryed IP based marking that is not good in case of DHCP clinets off course.
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Vlan1
no ip address
bridge-group 1
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip address 192.168.X.X 255.255.255.0
no ip redirects
no ip unreachables
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly
zone-member security in-zone
ip tcp adjust-mss 1452
bridge 1 protocol ieee
bridge 1 route ip
Urbanek
Solved! Go to Solution.
11-25-2009 09:45 AM
Hello Mark,
you may only approximate this with an extended ACL that matches source ip address of device connected to Fas8 and then you apply a policy-map inbound on BVI interface
Hope to help
Giuseppe
11-25-2009 09:45 AM
Hello Mark,
Hope to help
Giuseppe
11-25-2009 09:59 AM
Thanks, I have on mind to mark all trafic from FE8 -> DSCP er, and then I will after NAT on Dialer make policy-map to search for DSCP er and give bulk.
11-26-2009 07:59 AM
Yes there is no posibility to mark Ethernet port as origin of traffic. So must be done on IP address or protocol.
11-26-2009 08:09 AM
You can create policy-map and attach this policy-map to the FE 8 interface
policy-map DSCP-EF
class class-default
set dscp ef
interface fastethernet 8
service-policy input DSCP-EF
You can change the DSCP marking to the intended one in your configuration.
Edison
11-26-2009 08:31 AM
Thanks I tryed this
look - I have it on FE6 now I know, for testing only on FE6 is my testing notebook that generate traffic
class-map match-any Dialer1_out
match dscp ef
class-map match-any class_local_FE8_mark
match access-group name Rule_local_FE8_mark
policy-map CCP-QoS-Policy-1
class Dialer1_out
priority percent 33
class Dialer1_out
priority percent 33
policy-map policy_local_FE8_mark
class class_local_FE8_mark
set dscp ef
service-policy input policy_local_FE8_mark
interface Dialer1
description $FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
ip mtu 1492
ip flow ingress
ip flow egress
ip nat outside
zone-member security out-zone
encapsulation ppp
dialer pool 2
dialer-group 2
ppp authentication chap pap callin
ppp chap hostname X
ppp chap password 0 X
ppp pap sent-username X password 0 X
no cdp enable
service-policy output CCP-QoS-Policy-1
ip access-list extended Rule_local_FE8_mark
remark CCP_ACL Category=256
permit ip any any
but all trafic is in class-default and not in Dialer1_out class
11-26-2009 08:36 AM
If I understand you correctly, you want to mark all traffic entering switchport FE 8 to a certain DSCP value.
I recommended to use the class class-default on a policy-map but I don't see that in your configuration.
You are matching on ip protocol, this won't work.
Please try the config I posted before and once you do, generate traffic that enters FE 8 and post the show policy-map interface output.
Edison.
11-26-2009 09:09 AM
Yes based on your recomend now I got
policy-map DSCP_EF
class class-default
set dscp ef
service-policy input DSCP_EF
service-policy output DSCP_EF
Router#show policy-map interface output
FastEthernet6
Service-policy output: DSCP_EF
Class-map: class-default (match-any)
232 packets, 13920 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
QoS Set
dscp ef
Packets marked 0
Now i get that packets on class-default on port FE6 there is ping command
Now are packets marked with ef?
So I can make other policy on dialer to look for EF and then make qos?
11-26-2009 09:21 AM
I recommend to mark on input, yet you applied the service-policy on input and output direction.
Your 'show policy-map interface' only includes the output from the 'service-policy output', I need to see the 'service-policy input' as well - that's where packets must be marked.
If you noticed in the output
QoS Set
dscp ef
Packets marked 0
No packets were marked while leaving the port, the intention is to mark packets as they enter the port.
What I need from you is to remove the 'service-policy output' from FE6 and post back with the 'show policy-map interface' with only the input policy-map applied.
Edison.
11-26-2009 09:32 AM
Thank you that you spend time with this.
policy-map DSCP_EF
class class-default
set dscp ef
ping command still goes and I tried also come TCP traffic (WWW browsing)
FastEthernet6
Service-policy input: DSCP_EF
0 packets, 0 bytes
Match: any
QoS Set
dscp ef
Packets marked 0
I noticed packets marked 0 after sending last reply.
11-26-2009 10:14 AM
And you are sure traffic is entering FE 6?
Clear the counters and post the output from typing 'show interface f6' and 'show policy-map interface'
Edison
11-26-2009 10:23 AM
and didn't found nothing wrong.
IOS 15.0.1M
Router#clear counters fastEthernet 6
Clear "show interface" counters on this interface [confirm]
Router#show interfaces fastEthernet 6
FastEthernet6 is up, line protocol is up
Hardware is FastEthernet, address is 0021.5556.35d5 (bia 0021.5556.35d5)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:00:37
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 2000 bits/sec, 3 packets/sec
75 packets input, 5836 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
111 packets output, 8830 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier
And it increase.
Last clearing of "show interface" counters 00:00:39
5 minute output rate 1000 bits/sec, 2 packets/sec
79 packets input, 6148 bytes, 0 no buffer
116 packets output, 9206 bytes, 0 underruns
Router#
And still same.
FastEthernet6
0 packets, 0 bytes
Match: any
QoS Set
dscp ef
Packets marked 0
11-26-2009 10:48 AM
Is not problem in BVI1 ?
11-26-2009 12:59 PM
I think the problem is that Fas6 is a port of an etherswitch module in an ISR router.
Probably QoS features are not supported on Etherswitch ports.
let's see the restrictions section of the link you have provided:
Traffic marking can be configured on an interface, a subinterface, or an ATM permanent virtual circuit (PVC). Marking network traffic is not supported on the following interfaces:
•Any interface that does not support CEF
•ATM switched virtual circuit (SVC)
•Fast EtherChannel
•PRI
•Tunnel
Fas6 should be a L2 only port that does not support CEF.
Hope to help
Giuseppe
11-26-2009 02:38 PM
