match metric
what match metric 61 53 83 103 47 mean?
Hall of Fame Super Bronze
Re: match metric
That's a 5-part EIGRP metric. If you use that match within a route-map, it will redistribute or block EIGRP metric specified above.
____
Please rate helpful posts.
Re: match metric
thanks, but what do u mean 5 part EIGRP metric?
Re: match metric
Eigrp & IGRP uses a composite metric which consists of the following 5 parameters
bandwidth, delay, Load, reliability & MTU
Hnece it is called a 5 part eigrp metric
see following link for more details
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009405c.shtml
HTH, rate if it does
Narayan
132
