Max number of default routes on a cisco 3700
Can any of you tell what are the max number of default routes on a Cisco 3700 with IOS 12.3?
Best regards,
Santi
1 ACCEPTED SOLUTION
Purple
Re: Max number of default routes on a cisco 3700
Hi Santi,
While you can configure as many default routes you want, the router will only install the first 16 that you configure into the routing table.
That is, the output of 'sh ip ro' and 'sh ip cef' will only have 16 of the configured default route next-hops...
Hope that helps - pls rate posts that help.
Paresh
Purple
Hi Santi,
Paresh
Hi Paresh,
Thank you for your clarification. It's really helpful.
Santi
Purple
It's my pleasure, Santi...
Paresh
125
