Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
MCAST, BGP and Inter-Domain MSDP
Im trying out a new lab witch is working fine for the first 3 min, after my VLC IGMP join, then my traffic is getting Pruned and dont know why.
I can see that my VLC host is still sending IGMP join reports for the channel.
It works perfectly >3min if directly connect the 2x L3 swithes (SW1 and SW2) and make an BGP peering between them.
AS65008 and AS65009 routers are multicast-routing enabled and have ip pim sparse-dense mode enabled on there link interfaces.
SW1 config:
interface FastEthernet0/15
no switchport
ip address 10.250.0.1 255.255.255.0
ip pim sparse-dense-mode
interface FastEthernet0/16
no switchport
ip address 10.250.1.1 255.255.255.0
interface FastEthernet0/18
no switchport
ip address 10.250.10.1 255.255.255.0
interface Loopback0
ip address 10.250.21.1 255.255.255.255
ip multicast-routing distributed
ip pim rp-address 10.250.21.1
ip msdp peer 10.250.22.1 connect-source Loopback0 remote-as 65002
ip msdp cache-sa-state
ip msdp originator-id Loopback0
router bgp 65001
no synchronization
bgp log-neighbor-changes
network 10.250.0.0 mask 255.255.255.0
network 10.250.1.0 mask 255.255.255.0
network 10.250.10.0 mask 255.255.255.0
!network 10.250.13.0 mask 255.255.255.0
network 10.250.21.1 mask 255.255.255.255
neighbor 10.250.0.2 remote-as 65008
neighbor 10.250.1.2 remote-as 65009
!neighbor 10.250.13.2 remote-as 65002
no auto-summary
SW1#sh ip bgp
*  10.250.11.0/24   10.250.1.2                             0 65009 65002 i
*>                  10.250.0.2                             0 65008 65002 i
*  10.250.22.1/32   10.250.1.2                             0 65009 65002 i
SW1#sh ip mroute
(*, 233.0.0.1), 00:06:32/stopped, RP 10.250.21.1, flags: SJC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    FastEthernet0/18, Forward/Sparse-Dense, 00:06:32/00:02:32
(10.250.11.2, 233.0.0.1), 00:06:32/00:01:59, flags: MT
  Incoming interface: FastEthernet0/15, RPF nbr 10.250.0.2
SW2
no switchport
ip address 10.250.2.1 255.255.255.0
no switchport
ip address 10.250.3.1 255.255.255.0
no switchport
ip address 10.250.11.1 255.255.255.0
interface Loopback0
ip address 10.250.22.1 255.255.255.255
router bgp 65002
no synchronization
network 10.250.2.0 mask 255.255.255.0
network 10.250.3.0 mask 255.255.255.0
network 10.250.11.0 mask 255.255.255.0
network 10.250.22.1 mask 255.255.255.255
neighbor 10.250.2.2 remote-as 65008
neighbor 10.250.3.2 remote-as 65009
!neighbor 10.250.13.1 remote-as 65001
no auto-summary
ip pim rp-address 10.250.22.1
ip msdp peer 10.250.21.1 connect-source Loopback0 remote-as 65001
When my traffic is getting pruned:
SW1#sh ip mroute
(*, 233.0.0.1), 00:10:22/stopped, RP 10.250.21.1, flags: SJC
    FastEthernet0/18, Forward/Sparse-Dense, 00:10:22/00:02:11
(10.250.11.2, 233.0.0.1), 00:04:37/00:01:34, flags: MT
    FastEthernet0/18, Forward/Sparse-Dense, 00:04:37/00:02:11
SW1#sh ip msdp sa-cache
MSDP Source-Active Cache - 1 entries
(10.250.11.2, 233.0.0.1), RP 10.250.22.1, BGP/AS 65002, 02:09:00/00:05:28, Peer 10.250.22.1
SW2#sh ip mroute
(*, 233.0.0.1), 01:13:13/stopped, RP 10.250.22.1, flags: SP
  Outgoing interface list: Null
(10.250.11.2, 233.0.0.1), 01:13:13/00:02:53, flags: PTA
  Incoming interface: FastEthernet0/18, RPF nbr 0.0.0.0
SW2#sh ip rpf 10.250.10.2
RPF information for ? (10.250.10.2)
  RPF interface: FastEthernet0/15
  RPF neighbor: ? (10.250.2.2)
  RPF route/mask: 10.250.10.0/24
  RPF type: unicast (bgp 65002)
  RPF recursion count: 0
  Doing distance-preferred lookups across tables
SW2#sh ip msdp sa-cache
MSDP Source-Active Cache - 0 entries
Under all this, the 2 VLC players can ping each other all the time, no packet loss.
Lo0 can ping each other also.
Hope any one have an input ....
Cheers Martin
VIP Super Bronze
What IGP are you using OSPF, ISIS, RIP etc...?
Hello Reza,
Im not running any IGP, have included my top. drawing in PDF.
Annon. my LAN net in BGP + it is working the first 3 min :-) then it is Pruned.
Cheers Martin
Have a look at the below documents I posted on CSC which may be useful for your lab setup
https://supportforums.cisco.com/docs/DOC-8293
https://supportforums.cisco.com/docs/DOC-8375
Hope this help
Hello Marwan,
I know your posts, top $$$ i must say. My test lab is build based on your config :-)
Know i have forgotten to enable sparse-dense mode on the Lo0 interfaces but can this do
that after 3min of working mcast, my traffic is Pruned ??
Martin
Re: MCAST, BGP and Inter-Domain MSDP
Try to disable mcast SPF !
As65008 and 9 has to run there own RP right? but is it nessary for as65001 and as65002 to MSDP Peer with 8 and 9 or is it enough with my Peer between 1 and 2??
Well it's all about what you
Want to achieve msdp is used to exchange multicast sources info between different multicast domains
And at the same time your underlaying infrastructure has to support pass mcast traffic
And sometimes msdp used for redundant RPs but it is not in your lab topology case
See the below link for some more details
http://www.cisco.com/en/US/docs/ios/solutions_docs/ip_multicast/Phase_1/mcst_p1.html
Hope this help
Got it up and running.
Had to msdp peer A-to-B and B-to-C and not A-to-C :-) Not the way i wanted but okey, it works now
Cheers and thx
Glad to know that
Do you mean younset up the switches and the routers as msdp peers
In a full mesh topology ?
It dose make sense as immentioned above it used for edge devices between different multicast domains and as described in cisco link above
Yea, the switch A and router B is msdp peering. Switch C is msdp peered with router B. Router/AS B is an isp so i didnt want to msdp Peer with them, thats why i wanted A and C talken together directly.
803
