01-09-2008 04:46 AM - edited 03-03-2019 08:11 PM
After configuring EIGRP using MD5,AAA authentication is not taking.
Pls suggest.
regds
Solved! Go to Solution.
01-10-2008 12:23 AM
one more thing in ur config..
key chain TTL
key 1
key-string 7 15200419302F
accept-lifetime 15:45:00 Jan 9 2008
infinite
send-lifetime 15:45:00 Jan 9 2010 infinite
key 2
key-string 7 113B1610231759
accept-lifetime 15:45:00 Jan 9 2008 infinite
The send life time starts form Jan 9 2010!!!!.Make it same as of accept-lifetime date and check..
so i think this is not sending any key now.What is the configuration on other end routers??
01-09-2008 04:53 AM
AAA for your lines? Is EIGR working ok?
01-09-2008 05:04 AM
Nasheer
You do not provide much detail to work from. The symptoms that you describe suggest that there may be a connectivity problem between your router and your authentication server. Can you verify whether the router is able to ping the authentication server (using whatever source address may have been specified)?
My guess is that there is some problem with the EIGRP authentication and that you lost some routes from your routing table.
Rick
01-09-2008 09:53 PM
01-09-2008 10:08 PM
I think you are missing the eigrp authetication configuration
Add following statements under your interfaces:
ip authentication key-chain eigrp 7 TTL
ip authentication mode eigrp 7 md5
HTH,
regards,
shri :)
01-09-2008 10:08 PM
HI Nasheer, [Do Rate if HELPS]
Please install the below configuration in your Router: (AAA - Authentication, Authorization and Accounting):
AAA:
aaa authentication login vty tacacs+ local
aaa authentication login conuser tacacs+ local
aaa authentication enable default tacacs+ enable
aaa authorization commands 1 default tacacs+ none
aaa authorization commands 15 default tacacs+ none
aaa accounting commands 15 default start-stop tacacs+
tacacs-server host xxx.xxx.xxx.xxx
tacacs-server key 7 08124D601035103D32535554
In your attached Configuration, AAA commands are missing and in adddition for EIGRP there are no MD5 authentication enabled.
Do RATE if HELPS
Best Regards,
Guru Prasad R
01-09-2008 10:21 PM
Hi guru,
Still not working.I had EIGRP commands and AAA.
Pls suggest.
regds
01-09-2008 10:23 PM
HI Nasheer,
Can you pls POST the sh run of Router in which the configurations are installed.
>> Is the Router can able to PING the TACACS Server ??
Do RATE ALL HELPFUL POSTS
Best Regards,
Guru Prasad R
01-10-2008 12:23 AM
key chain TTL
key 1
infinite
key 2
01-11-2008 06:18 AM
Thanks Arun.I had configured as 2010 because it should accept the given key only up to that period.
I had corrected the configuration.
regds
01-10-2008 12:25 AM
01-10-2008 12:52 AM
hi,
good point by arun...
plz check the send-life time configured and make it same as accept life-time at least make it in year 2008.
HTH,
regards,
shri :)
