MDIX AUTO fearure ????
I want to ask you about the fearture auto mdix
can i change it no auto mdix to auto mdix is live system is there any effect on the live system
Silver
Re: MDIX AUTO fearure ????
You can change, it's only used for automatic cable type detection, I mean between two swithces normally you have to use straight cable, but with mdix auto you can use cross-over and it works.
If you change this settings on a live port it will not shutdown it.
bye
FCS
Please rate me if I helped.
Thanks for the Ans ,, will it reset the port ???
and is it possible that we enable it Globally on all ports .
or it will enabled on all interface i=on by one
hi...
no it will not reset the port...
and i dont think so you can enable it globally on all port so you have to go for one by one configuration...
The Auto-MDIX feature is enabled by default on switches running Cisco IOS Release 12.2(18)SE or later. For releases between Cisco IOS Release 12.1(14)EA1 and 12.2(18)SE, the Auto-MDIX feature is disabled by default.
hope this will help you
rate this post if it helps
regards
Devang
Green
Correction: Between switches (or any other pair of similar devices), you'd normally have to use a cross-over cable.
Auto-MDX will detect straight-through or cross and adjust the port role accordingly.
FWIW
Scott
189
