Community Member
Memory upgrade cisco 2651xm
I upgrade my cisco2651 from 64 to 256 mb ram (2x 128).
This is the boot output after installing the modules.
System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Copyright (c) 2003 by cisco Systems, Inc.
C2600 platform with 262144 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x59421c
Self decompressing the image : ################################################################################################ [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
00036F 0X00103980 C2651XM Dual Fast Ethernet
000064 0X0002E500 Two port Voice PM
00027C 0X0013E440 DSP AIM with 4 DSPs
0X000F3BB0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X00574E70
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 6Mb.
Using 4 percent iomem. [6Mb/128Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(8)T5, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 21-Jun-02 08:50 by ccai
Image text-base: 0x80008074, data-base: 0x80A2BD40
cisco 2651XM (MPC860P) processor (revision 0x400) with 124928K/6144K bytes of memory.
Processor board ID JHY0811K3Z1 (1905371758)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
49152K bytes of processor board System flash (Read/Write)
As you'll see the system recognize "C2600 platform with 262144 Kbytes of main memory" but when I show the version I get "cisco 2651XM (MPC860P) processor (revision 0x400) with 124928K/6144K bytes of memory."
In case I have to install an IOS that require more than 128 MB ram is my router able to support it?
Thank you.
1 ACCEPTED SOLUTION
Re: Memory upgrade cisco 2651xm
Your ROMmon is correct 12.2(8r). However, your IOS is old. You will not be able to use memory greater than 128MB because of your installed IOS. You need to upgrade to IOS higher than 12.3T to be able to show 256MB in the "show version" output and also use it.
Check the last 2 pages of this document http://www.cisco.com/en/US/prod/collateral/routers/ps259/prod_qas0900aecd800f71dd.pdf
Community Member
I upgraded the IOS to 12.3(26) but still I don't see the entire memory with the command sh ver.
I can't understand that because on another 2651xm I can show the memory even if the IOS is older then mine. This the output
Cisco IOS Software, C2600 Software (C2600-IPVOICE-M), Version 12.3(11)T6, RELEAS
E SOFTWARE (fc3)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 02-Jun-05 15:38 by ccai
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
GwVoice_Stiva uptime is 4 weeks, 23 hours, 4 minutes
System returned to ROM by reload at 12:47:31 cet Wed Jun 10 2009
System restarted at 12:50:21 cet Wed Jun 10 2009
System image file is "flash:c2600-ipvoice-mz.123-11.T6.bin"
Cisco 2651XM (MPC860P) processor (revision 0x401) with 253952K/8192K bytes of me
mory.
Processor board ID JHY0909K2B9 (1032466881)
2 FastEthernet interfaces
31 Serial interfaces
2 ISDN Basic Rate interfaces
1 Channelized E1/PRI port
1 ATM AIM
4 Voice TE BRI interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
What's the difference with mine?
Hall of Fame Super Gold
Likely faulty memory module.
Community Member
Hi Medan,
thank you.
I upgrade the system to a non T version this was the problem.
Once upgraded to the latest T version (12.4.15T9) the sh ver now indicate 256 mb ram.
Thank you
919
