03-31-2008 08:48 AM - edited 03-03-2019 09:20 PM
how do I check the current memory of router?
sh memory
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 64478360 146307940 30070236 116237704 82825472 112753508
I/O E000000 33554432 3659264 29895168 29860880 29887580
Transient 6D000000 16777216 17864 16759352 16759352 16746312
regarding above output,
total memory is 146M
used memory is 30M
free memory is 116M
what does it mean "lowest" and "largest"?
there are 256M memory in the router, why 110M memory disappear? what is going wrong?
rdgs
Solved! Go to Solution.
03-31-2008 01:11 PM
"there are 256M memory in the router, why 110M memory disappear? what is going wrong?"
The missing 110M is likely both from I/O and IOS usage.
E.g. (2811 with 256M)
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
(249,856K + 12,288K = 262,144K)
Directory of flash:/
1 -rw- 38472492 Oct 19 2007 20:09:02 +00:00 c2800nm-advipservicesk9-mz.124-17.bin
Compress images vary in actual size reduction but 2 x is usually close. So the above image would likely needs about 75 to 80 M.
wan01#sh mem st (only totals shown)
Total(b)
174547040
12582912
262144000-
about 75M - which is expected for the running IOS image
03-31-2008 01:11 PM
Total(b)
174547040
12582912
262144000-
