Merging two Networks
Hello All,
My company has acquired a smaller company that has a Fios connection and Sonicwall 2040 as their sole connection. They are utilizing an address scheme of 10.0.0.x. My network uses a 192.168.x.x network and BGP/IPFR to network all of the remote locations. I have my new router and full t1 plugged in at this new location with an 1841 router one ethernet port is configured w/ 10.0.0.2 and one w/ 192.168.110.1
Problem is getting them to see the 100.1.x.x network back at my home office. I have setup a static route on the Sonicwall and on my ATM router. But the when I do a trace route the traffic dies off when it hits the BGP network. Do I need to contact my ISP? Is the IPFR set up to only forward 192.168 traffic? (See attached diagram)
1 ACCEPTED SOLUTION
Re: Merging two Networks
You added the 10.0.0.0/24 network on the wrong server as far as I can see. You need to ad it on the loveland router not on the atm router.
regards
Rogier
Does the route towards 100.1.X.X appears on the loveland_ground_masters router?
regards
Rogier
The Loveland router connects to the 100.1.x.x network via BGP. The route is advertised via BGP
Sample of SH BGP command.
Network Next Hop Metric LocPrf Weight Path
*> 0.0.0.0 192.168.252.149 0 13979 65000 i
*> 100.1.0.0/16 192.168.252.149 0 13979 65000 i
*> 192.168.1.0 192.168.252.149 0 13979 65000 i
Tracing the route to 100.1.1.41
1 192.168.252.149 8 msec 8 msec 8 msec
2 192.168.254.2 [AS 13979] 48 msec 48 msec 48 msec
3 100.1.1.41 [AS 65000] 68 msec 52 msec 48 msec
Loveland_Ground_Masters#
Is it possible to manually define the next hop attribute in BGP?
I've defined the 10 network under my BGP on my 1841 (loveland) router.
router bgp 65110
no synchronization
bgp log-neighbor-changes
network 10.0.0.0 mask 255.255.255.0
neighbor 192.168.252.149 remote-as 13979
neighbor 192.168.254.2 remote-as 65000
no auto-summary
So it advertises the 10.0.0.x network now when i do the SH BGP command:
*> 10.0.0.0/24 0.0.0.0 0 32768 i
*> 192.168.10.0 192.168.252.149 0 13979 65010 i
But it has a next hop of 0.0.0.0
Is on your ATM router the way back to 10.0.0.0/24 known? Did you add the 10.0.0.0/24 network on the loveland router in your BGP AS?
regards
Rogier
on the ATM Router i'm unable to get to the 10 network either.
When I do a traceroute back to the 10 network it dies off when it hits the IPFR/BGP
BRICK_ATM#traceroute 10.0.0.2
Tracing the route to 10.0.0.2
1 192.168.254.1 12 msec 12 msec 20 msec
2 192.168.254.2 28 msec 24 msec 28 msec
3 * * *
I specified a manual route statement.
ip route 10.0.0.0 255.255.255.0 192.168.252.149
As well as defining the 10.0.0.x network in the Router BGP Statement:
router bgp 65000
no synchronization
network 0.0.0.0
network 100.1.0.0 mask 255.255.0.0
network 192.168.0.0
network 192.168.1.0
neighbor 10.0.0.2 remote-as 65110
neighbor 192.168.252.150 remote-as 65110
neighbor 192.168.254.1 remote-as 13979
neighbor 192.168.254.34 remote-as 65017
neighbor 192.168.254.182 remote-as 65054
no auto-summary
Any help would be appreciated. Thanks,
regards
Rogier
305
