metric and route path choosing
I have the following routing table:
ip classless
2.0.0.0/30 is subnetted, 1 subnets
C 2.2.2.0 is directly connected, Loopback2
3.0.0.0/30 is subnetted, 1 subnets
C 3.3.3.0 is directly connected, Loopback3
9.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
S 9.9.9.0/28 [100/0] via 3.3.3.3
S 9.9.9.0/27 [10/0] via 2.2.2.3
S 9.9.9.16/28 [100/0] via 3.3.3.3
When I try go to 9.9.9.1 or 9.9.9.18 i.e., I pass through Loopback3 (3.3.3.3):
Tracing the route to 9.9.9.2
1 3.3.3.2 4 msec 0 msec 0 msec
2 ...
Tracing the route to 9.9.9.18
1 3.3.3.2 0 msec 4 msec 0 msec
2 ...
I can't understand - why? If this route have highest distance (100) from route through Loopback2 (2.2.2.2) with distance 10. Just because the prefix length?
I read this: http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094823.shtml but I don't see there relationship between AD, metric and prefix length. Who is preffered?
According to my results - the prefix length is preferred than AD..
1 ACCEPTED SOLUTION
Re: metric and route path choosing
Prefix length is always preferred first. So the longest match route in the routing table will always be preferred.
Next, suppose you have 2 routes with the same length subnet mask, AD will be used to select route.
Next, suppose you have 2 routes with the same length subnet mask and equal AD, the metric will be used for route selection.
Hope this helps! If so, please rate.
I believe that you should also mention that with OSPF things change a bit too.
After you consider the longest prefix you'd then prefer route type O, then O IA, then E1 and then E2 before considering costs.
Vlad
117
