12-25-2007 09:08 PM - edited 03-03-2019 08:02 PM
We have 10Mbps Metro Ethernet link terminated in the FE.Problem is when the link is giving problem it is not switching over to the redundant path bcoz the FE0/1 is showing UP only when we remove the cable/shutdown the interface it is switching over.
Can you provide the solution when there is a metro link problem it should transfer to the redundant link.
Note : HSRP configured in FE0/0.
regds
Nasheer
12-26-2007 03:25 AM
This is a common problem when your last mile is ethernet.
You need to use enhanced dobject tracking with HSRP for this.
Have a look here
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t15/fthsrptk.htm
Narayan
12-26-2007 07:16 AM
I had the same probelm using EIGRP and MetroE. I used the following two commands on the ethernet interface to fine tune EIGRP hold and hello timers which worked great failing to a higher cost link. Not sure if this helps you with HSRP but good luck:
ip hello-interval eigrp 999 1
ip hold-time eigrp 999 4
