MGCP 3825
Hey guys,
I have a 3825 gw, mgcp , that has a pri configured on it. PRI is up and working. The CCM(4.1.3sr3) that controls the GW sees it with no problem. When I try and configure route groups for a route list, CCM does not see the PRI as an available selection. It only sees my FXO ports. When I configure a route pattern for outbound calls, I can see the PRI there. I am trying to configure a route list that contains the PRI group as 1st choice and another FXO group as 2nd choice. Any suggestion on why it does not show up as available ports, when trying to config a route group? Thanks
Re: MGCP 3825
Make sure you do not have any other patterns going directly to the gateway. Also, make sure the PRI is registered to CM..
Re: MGCP 3825
kelvin,
That was it. One route pattern had that pri assigned to it. Thanks BV
104
