MGX 8850 port and channel relationship
I'm curious how to build PVC through BPX to 8850 MGX via CLI. Specifically, how the channel and port relationship works between the MGX and BPX on a frame-frame service.
Say we have circuit
MGX-BPX-(atm_cloud)-BPX-MGX
using FRSM cards on MGX 8850 both sides
Usually the connection on the BPX would look like
Trunk.Trunk.Card.Channel
Using previous example say MGX is using card 1 port 1 channel 16
and connecting to BPX via trunk 9.1
Then on the BPX the connection would be
9.1.1.16.
Now with a MGX 8850, I created the connection via Cisco WAN Manager, it does not go via this format.
Real world example:
I had a frame relay connection and on the MGX it was on card 3 port 32 DLCI 16 with channel 19. This MGX has a trunk on 11.1 to the BPX.
Now when I check the BPX for which connection it sees this circuit on, it is 11.1.1.22??
How does Cisco WAN Manager build this connection logically, so I can figure out how to build this manually?
Thank you!
  • WAN Routing and Switching
1 REPLY
Silver
Re: MGX 8850 port and channel relationship
A profile contains most of the same attributes as the corresponding object. Those attributes of the object that are not included in the profile, are expected to be unique for each object. For example, the DLCI on a Frame Relay PVC could not be a profiled attribute.Refer the following URL for more information
http://www.cisco.com/en/US/products/sw/netmgtsw/ps2035/products_configuration_guide_
104
