Community Member
MHSRP config using 1721 routers
Hi all,
I would like to configure Multigroup HSRP for load balancing & High Availability . Several ethernet ( LANCE & QUICC ) controllers in low end products will not support MHSRP . Does Cisco 1721 Modular Access router support MHSRP ?
If it supports , can we do stateful NAT on that ?
Kindly revert back to me .
Re: MHSRP config using 1721 routers
Cisco 1721 Modular Access Router does support HSRP and NAT as well.
Have a look at this URL -->
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00800920ec.html
Have a look at this URL for HSRP -->
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008042fbb3.html
Hope this helps...
AbhisheK
Please rate all helpful posts!!!
Hi Senthil
You can verify the below link to find out whether you box supports HSRP.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
AFAIK i don't see any issues in having MHSRP if your box supports HSRP..
regds
256
