Community Member
Minimum image level to do BGPv4, 2851
Folks, what's the minimum image I should use if I need to run BGPv4 on my 2851 router?
I know that the c2800nm-advipservicesk9-mz.124-9.T5.bin will do BGP for example, but my question is, is this the image the one can give me BGP and it is the most cost effective one?
I know how to use the feature navigation software, but I see so many images there which can support BGP that it is hard to find out which ones are the minimal I need.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Minimum image level to do BGPv4, 2851
Marlon
I believe that BGP in the Advanced Security image has been a moving target. A while back I remember looking and there was no support for BGP in the Advanced Security image (I had a customer running the Advanced Security image who wanted BGP). I just tried it on a router running 12.4(15)T and it lets me configure BGP just fine. I am not clear whether it is an early 12.4/later 12.4 thing or a 12.4/12.4T thing. But I can tell you for sure that there are some versions of the Advanced Security feature set that do have BGP support.
Rick
Marlon
According to the Feature Navigator on the Cisco site you get support for BGP with Advanced Security, Advanced IP Services, and Advanced Enterprise Services. I am not sure that any of these is particularly more cost effective than any other.
Rick
Community Member
Funny that the "Advanced Security" is supposed to give me BGP, because when I try to use image c2800nm-advsecurityk9-mz.124-3i.bin (and I checked the image feature using the feature navigation) I see no support for BGP there.
If I do 'router BGP' on that image, I am getting 'command not supported in this image'. Not sure if I understand this one.
Marlon
Rick
330
