Mistake pls help (Urgent)
Hai
Was trying to break the password.instead of giving 0x2142 ..by mistake typed 0x2132 ..after restarting its not taking the Rom moniter mode..how do i can change this ...while booting its showing invalied charectrs ...
i am using 1800 series router
rommon-pref Select ROMMON
·›5Ÿ5ò¶£'>ô ô ôôôôôôôôôôôôôôôôôôôôôôôô ôôôô5555555555555555555555''&'&³ ³&ó÷³þ
÷³þ÷±þ÷'‡÷·þ·þ·þõ÷·þ÷·þ±þô÷ô÷·þõ÷·þõ÷±þ²63þ°þ·fõö³þô'¶þ 4¯µ>3þ¶£5¿'>3¶£'>ôôôôôô
ôôôôôôôôôôôôôôôôôô55555555555555555555555555555555555555555555555555555555555
1 ACCEPTED SOLUTION
Re: Mistake pls help (Urgent)
Hello there!
You changed the console speed. Try put your client to 19200 baud and see if you can see normal characters when you connect. If 19200 does not work try other value, but I believe is 19200.
Tell me if it is working!
Good luck!
Cheers,
Calin
Hello there!
Good luck!
Cheers,
Calin
Hai,
calin done the same thing ....its happening thanks a lot ...
ujil
Great :)
Good luck!
105
