MLPPP 3xT1 Slow also want flow based for Voice
allan.wells
Level 3
Level 3
I have done some testing and the links seem realy slow for example I have been TFTPing an Image between routers over the wan R1---PPP---MPLS---ppp---R2
I do a show interface ser0/1/0 0/2/0 and 0/3/0 and the output is below..
5 minute input rate 16000 bits/sec, 4 packets/sec
5 minute output rate 1000 bits/sec, 4 packets/sec
I can initiate a extended ping between them and thats not real quic either considering one side is 2 xt1 and this one 3xt1
Also we are going to put voice over these links so Im wondering if IP CEF will distribute traffic per flow over one of the Multilink interfaces as i dont want the Voice traffic to be load shared for Obvious reasons.
So basicaly my questions are
1. Will voice streams be routed over 1 multilink interface if IP CEF is running (flow based).
2.Tried ext ping and pkts over 1500 bytes fail will this cause issues at all. I dont want to adjust MTU If i dont need to.
3.Anything else I can do to the config to improve it.
Thanks Allan
Config Below
class-map match-all Sprint_Data_Class_A_Voice_Only
description LLQ_Priority_Queue_RTP_Bearer_Traffic
match access-group 111
class-map match-any Sprint_Data_Class_C
description Class_C_Data_Traffic
class-map match-any Sprint_Data_Class_B
description Voice_Signaling_&_Class_B_Traffic
match access-group 106
policy-map Traffic_Shape-LLQ_CBWFQ
class Sprint_Data_Class_A_Voice_Only
priority percent 35
class Sprint_Data_Class_B
bandwidth percent 25
class Sprint_Data_Class_C
bandwidth percent 15
class class-default
fair-queue
interface Multilink1
ip address 172.20.150.222 255.255.255.252
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
service-policy output Traffic_Shape-LLQ_CBWFQ
interface FastEthernet0/0
description Inside Interface
ip address x
ip nbar protocol-discovery
duplex full
speed 100
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0
description Sprint DS1 xxx
bandwidth 1536
ip unnumbered Multilink1
encapsulation ppp
no ip mroute-cache
no peer neighbor-route
no fair-queue
ppp multilink
interface Serial0/2/0
description Sprint DS1 #xxx
bandwidth 1536
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
interface Serial0/3/0
description Sprint DS1 #xxxx
bandwidth 1536
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
ip classless
ip route
no ip http server
no ip http secure-server
access-list 106 permit udp any any eq 2427
access-list 106 remark UDP Port 2427 MGCP-CallManager_GW Control
access-list 106 permit tcp any any eq 2428
access-list 106 remark TCP Port 2428 ISDN_L3_Backhaul_To_CallManager
access-list 106 permit tcp any any range 2000 2002
access-list 106 remark TCP Port 2000_To_2002 SCCP_Signaling
access-list 111 permit udp any any range 16384 32767
access-list 111 remark UDP Ports 16384 32768 Voice_Bearer_Traffic
Multilink1 is up, line protocol is up
Hardware is multilink group interface
Internet address is 172.20.150.222/30
MTU 1500 bytes, BW 4608 Kbit, DLY 100000 usec,
reliability 255/255, txload 1/255, rxload 2/255
Encapsulation PPP, LCP Open, multilink Open
jeremyneedle
I know this reply is terribly late, but overall using multlink is going to add a bit of latency to your connection. Remember its adding 6 bytes to each frame
I see in your config you have fragmenting disabled. Depending on your service provider, what they have on the other end & how they configured it, you may actually want to turn that back on & add "ppp multilink interleave"
And as for voice, I've had just horrible results trying to use voip over multilink ppp. It was so bad for this client I had in NY, we actually ended up splitting the traffic via route maps so that all voip would go over one of the T1 lines, and I multilinked the other two and used them for everything else
Fortunately LRE's availability has increased significantly in the past 5 years and its cost has come down as well
anyway, i know this post is a decade late. hopefully someone else who has this problem will find this note and if possible, avoid bonded T1's like th bubonic plague. Pay the extra $ and get fiber!
your config looks okay, is the other side configured with the same multilink parameters ? You could try and configure 'ppp multilink interleave' and see if that makes a difference...
As with regard to CEF, the default is per-destination load-balancing (that means that indeed your load sharing will be per-flow).
GP
don.fortes
I don't think you have a problem with your configurations. I believe the problem is with cisco's Multilink. We have a good number of links with multilink configured, cisco cases opened and still waiting on cisco to find the issue.
Issues I have seen with the multilink configured.
1. Pings end to end are not good.
2. Slowness in the network.
3. High output drops on the multilink, all issues clear when removed from multilink.
jeremyneedle
