mlppp over 2 ds3s
I'd like a second opinion on the following config. I don't believe I need CEF on in the following config if MLPPP is doing its job. Any comments?
Side A
version 12.4
no service pad
service timestamps debug uptime
service timestamps log datetime msec localtime
service password-encryption
hostname Side_A
enable password
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip domain lookup
multilink virtual-template 1
interface Loopback0
ip address 192.168.1.57 255.255.255.252
interface FastEthernet0/0
ip address 192.168.1.50 255.255.255.248
duplex full
interface Serial2/0
no ip address
encapsulation ppp
dsu bandwidth 44210
framing c-bit
cablelength 10
clock source internal
serial restart-delay 0
ppp multilink
interface Serial2/1
no ip address
encapsulation ppp
dsu bandwidth 44210
framing c-bit
cablelength 10
ppp multilink
interface Virtual-Template1
ip unnumbered Loopback0
ppp multilink
ppp multilink fragment disable
ip default-gateway 192.168.1.49
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.49
ip route 192.168.1.88 255.255.255.252 192.168.1.58
ip route 192.168.1.90 255.255.255.255 192.168.1.58
no ip http server
control-plane
end
Side_A#
Side B
version 12.4
hostname Side_B
enable password
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip domain lookup
interface Loopback0
ip address 192.168.1.58 255.255.255.252
ip address 192.168.1.89 255.255.255.252
duplex full
interface Serial1/0
no ip address
encapsulation ppp
dsu bandwidth 44210
framing c-bit
cablelength 70
ppp multilink
interface Serial1/1
no ip address
encapsulation ppp
dsu bandwidth 44210
framing c-bit
cablelength 70
ppp multilink
ppp multilink
ip default-gateway 192.168.1.57
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.57
no ip http server
control-plane
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
end
Side_B#
Hall of Fame Super Silver
Re: mlppp over 2 ds3s
Sean
The multilink part looks pretty straightforward with the exception of its IP addressing. I think you are creating a problem by assigning these addresses to loopback interfaces and then doing ip unnumbered on the virtual-template. I think you would be much better off to just assign the addresses on the virtual-template. I think it is particularly an issue on side_B where your default route (ip route 0.0.0.0 0.0.0.0 192.168.1.57 ) and your default gateway are pointing to the subnet connected on the loopback interface. I think this is also an issue with 2 of the static routes on side_A:
I believe that you should leave cef enabled. I think that your comment about not needing cef is based on the assumption that cef does load balancing and with MLPPP you have a single logical outbound path not load balancing. But cef does a lot more than just load balancing. Basic decisions like whether to forward out the FastEthernet or the virtual-template are enhanced by cef.
Rick
Thanks for your comments.
I'll look into the loopback/unnumbered. I followed the examples for configuration. I'll go over them again .. make sure I didn't miss anything. Regarding CEF that makes sense.
Found the original example I used
Point-to-Point Protocol (PPP)
Multilink PPP on Back-to-Back Routers with Multiple Serial Interfaces
Example 2: Virtual Template
Router1 - Cisco 2503
Current configuration
version 12.2
hostname Router1
username Router2 password 0 abc
ip subnet-zero
no ip domain-lookup
!--- Applies the virtual interface template to the multilink bundle.
interface Loopback0
ip address 192.168.10.2 255.255.255.0
!--- The loopback address is used by virtual-template 1.
!--- Interface virtual-template is a logical interface that creates
!--- virtual access interfaces dynamically and applies them to
!--- physical serial interfaces.
!--- Always unnumber the virtual-template to an UP interface.
!--- Do not assign a static IP.
ppp authentication chap
ppp multilink
!--- Enables multilink PPP on the virtual-template interface.
interface Serial0
no ip address
encapsulation ppp
pulse-time 1
ppp multilink
interface Serial1
no ip address
encapsulation ppp
pulse-time 1
ppp multilink
ip classless
line con 0
line aux 0
transport input all
line vty 0 4
login
end
Router2 - Cisco 2503
Current configuration :
version 12.2
hostname Router2
username Router1 password 0 abc
ip subnet-zero
no ip domain-lookup
interface Loopback0
ip address 192.168.20.1 255.255.255.0
ppp multilink
interface Serial0
no ip address
encapsulation ppp
no fair-queue
clockrate 56000
pulse-time 1
ppp multilink
interface Serial1
no ip address
encapsulation ppp
no fair-queue
clockrate 56000
pulse-time 1
ppp multilink
ip classless
line con 0
line aux 0
line vty 0 4
end
The configuration above describes the virtual template configured on Router1 and Router2. In this example, both
routers are configured with virtual templates. The routers are connected back-to-back, and the multilink session
does not idle out. No static routes are needed: a host route is installed after PPP negotiations.
Use Cisco IOS Software Release 11.3 or later to use virtual template for PPP multilink.
The virtual template command dynamically creates a virtual access interface and applies them to physical serial
interfaces with the multilink virtual-template command. The parameters (such as ppp authentication chap) configured
in interface virtual template are applied for both serial interfaces. The ppp multilink command in the interface
virtual-template bundles the physical serial interfaces to form a virtual-access in order to aggregate the
bandwidth.
Sean
I am glad that you found and posted the example that you followed. It is certainly pretty specific in its comment about not assigning a static IP address to the virutal-template and using ip unnumbered instead. I am not sure why this is but the example certainly says so.
Given the advice to use unnumbered let me approach my concern from a slightly different perspective. The problem is not so much that you used ip unnumbered but is the fact that you attempt to define a connected subnet on both loopback interfaces. Your first loopback is 192.168.1.57 255.255.255.252 and the second loopback is 192.168.1.58 255.255.255.252. When you use this default route on Side_B ip route 0.0.0.0 0.0.0.0 192.168.1.57 I am not sure whether the router will believe that the next hop is on the loopback interface or is over the multilink. Given the reminder in the example that the PPP negotiation will put a host route into the routing table, it may be that you example will work. Even if it does work my instinct is that trying to put the same subnet on the loopback of two routers is not a good practice.
The example is clear that one loopback interface is 192.168.10.2 255.255.255.0 and the other loopback interface is 192.168.20.1 255.255.255.0. Two separate networks certainly avoids the problem.
It may be that you wanted to configure it so that the multilink used the same subnet on both ends. That is certainly good practice for most serial connections. The use of unnumbered makes things work even when the ends of the connection are not in a common subnet.
It would be interesting to try your configuration and see whether it works properly or not. If you do try it please post back to the forum with the results.
Rick
Thanks. You are correct about why I used a connected subnet. I'll give it a shot as seperate networks. The mlppp is supposed to automatically inject a route for the link.
I've added statics as I'm running a BGP peer across this link.
The link is working - routing and forwarding.
The reason I've been questioning the link at all is that I'm not seeing more than 9 Mbps across the two.
I've begun to wonder if the system is misreading the link speed and only allowing 4.2 Mbps based on the 42xxx kpbs of the modem speed.
More testing this week.
147
