08-20-2007 04:01 PM - edited 03-03-2019 06:23 PM
I have a remote customer location that has limited access provided by the LEC. Only DDS circuits are available. Using MLPPP, Can a Cisco router bundle together multiple DDS/DSO either terminated on a channelized DS1 card or individual WIC-1DSU-56K4 ports.
08-21-2007 01:08 AM
Yes you should be able to multilink individual WIC-1DSU-56K4 ports.
Just configure each link and associate them with the multilink group
On the other side, you can go for a version2 card which supports multiple channel groups and map each of them to 56K4 ports on the other side in multilink
Narayan
08-21-2007 06:25 AM
Thanks. I will give it a try.
