Modem Issue
TRACY HARTMANN
I have a router setup with a the following under aux 0
exec-timeout 5 0
modem dialin
modem autoconfigure type usr_courier
transport input all
speed 115200
flowcontrol hardware
The flat blue cable is connect to the US Robotics and a modem line.  I try to dial into the router with Putty or Hyperterminal and I get connected with no character returns.  I have tried different dip switch settings but no luck.  Any suggestions?
Martin Moran
Level 3
Level 3
Hi @thartmann,
You can try the following:
  • Change the speed line with the "speed <speed>" line configuration command to 9600 which is the deafult value for most of Cisco devices.
  • Make sure that in your terminal software you have the same speed value as your line aux 0 in the router.
HTH.
Rgrds,
Martin, IT Specialist
