modifying ip nat pool
I have a ip nat pool configured with 1 public IP.
I have obtained additional 3 public IP's. How do I modify my nat pool to include the new IP's ?
thanks
Sajiv
Re: modifying ip nat pool
U need to remove the earlier line and add
ip nat pool start IP end IP subnet mask
ip nat pool test 192.168.1.1 192.168.1.3 netmask 255.255.255.0
Mahmood
Thanks ! How do I remove the old ip nat pool ?
no ip nat pool ?
HI
Yes,and make sure that u first clear all the nat translations orelse u will not be able to remove it.
clear ip nat translations *
Mahmood
Thanks a lot for your help !
I already have one ip nat pool defined.
"ip nat pool wanpool 196.192.10.15 196.192.10.15 netmask 255.255.255.0
ip nat inside source list 102 pool wanpool overload
access-list 102 permit ip 10.1.0.0 0.0.3.255 any"
Now I added another ip nat pool say wanpool2.
ip nat pool wanpool2 196.192.10.20 196.192.10.23 netmask 255.255.255.0
ip nat inside source list 103 pool wanpool2 overload
access-list 103 permit ip 10.1.0.0 0.0.3.255 any
But when i add a static nat translation, it doesn't work.
ip nat inside source static tcp 10.1.1.55 80 196.192.10.20 80 extendable
what did I do wrong ?
152
