Module removal config stays
If I remove a module from cat65k will the configuration be there of the module?Logically it should loose the config?
Also if I replace STM-1 card or for eg anyother wan card in 76xx will the configuration be there?In the case of replacement it should be there.Any confirmation on this?
1 REPLY
Re: Module removal config stays
AFAIK you need to reset the switch/router to flush off the config lines related to the card removed.
regds
224
