02-15-2012 02:17 AM - edited 03-04-2019 03:16 PM
Hi Netpro
how to show all the module on the ASR 1004?
thanks
02-15-2012 05:19 AM
Try this
show diag [all | chassis | slot | subslot] eeprom
show platform
I used this link
http://www.cisco.com/en/US/docs/ios-xml/ios/interface/command/ir-cr-book.html
Alex
02-15-2012 09:25 AM
Hi Alex
I got "Forbiden Application"
Pls can u doenload and submit it
can u help me to administer a BGP Router connected to 2 different ISPs we r ucing public real as
thanks
02-16-2012 01:16 AM
02-17-2012 02:09 AM
thanks alex
10-21-2013 01:28 PM
I believe you have to specify on CLI 'card type' and then you will be able to see the serial interfaces. I ran into this same thing when I was installing a t3 sub module.
