Monitor ISDN calls with SNMP
tallan_os
I'm running three 2621 routers as ISDN access points and want to monitor the active calls with ipcheck monitoring tool. It appears that the MIB for this is CISCO-POP-MGMT-MIB, but this doesn't seem to work with the 2621. Anyone know of a way around this?
Thanks.
purohit_810
Level 5
Level 5
If you required MIB 2621 router, from
http://tools.cisco.com/ITDIT/MIBS/AdvancedSearch?MibSel=4621
Before download You required , router IOS name.
That you can get from " sh ver " command.
Generally that kinf of problem due to not select proper MIB.
You can look out following link. It will give you better idea.
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=CISCO-POP-MGMT-MIB
Dharmesh Purohit
bfbcnet
I'm also trying to do this. I have a 2821 router running 12.4(3g) with a channelised E1 interface, and I want to monitor how many DS0s are in use for capacity planning purposes.
I do this with some older 3640 routers by graphing the mib object cpmActiveDS0s (.1.3.6.1.4.1.9.10.19.1.1.4) and that works just fine, but the 2821 returns an absurdly high number as follows;
snmpwalk -c community -v 2c 2821_rtr .1.3.6.1.4.1.9.10.19.1.1.4
SNMPv2-SMI::enterprises.9.10.19.1.1.4.0 = Gauge32: 3615
There are only 12 channels on the system so the number 3615 is junk! Is CISCO-POP-MGMT-MIB not supported on the newer routers (2800 etc.)? If so how can we get the data that we need to manage the device effectively?
