Monitoring QOS traffic
What is the best way to monitor QOS traffic/utilisation on an interface ?
Re: Monitoring QOS traffic
show policy-map int f0/0 (or what ever your interface is)
show queueing interface
Are there any monitoring tools that can also provide this informtion ?
Silver
Netcordia has the NetMRI appliance ($$$) which has an additional module for monitoring QOS:
http://www.netcordia.com/products/quality-service.asp
Steve
I think that it is possible to use MRTG with the correct Cisco MIB for QOS. I think that they should use ISCO-CLASS-BASED-QOS-MIB:
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=CISCO-CLASS-BASED-QOS-MIB
It is not easy to find the correct OID I think that you have to try using snmpwalk or something like that
regards
gianrico
There are commercial software tools which can report the information like Concord eHealth. You can snmp the mib yourself but it is pretty complex. QOS models can be difficult and hiarchical and there is a lot to measure and report. To make it more complex the oid's will change on every policy change so you need to script for this condition too.
There are some extensions for Cacti which are all somewhat buggy:
http://forums.cacti.net/about7401.html
http://forums.cacti.net/post-50676.html
http://forums.cacti.net/about12485.html
(also checkout this bonus link http://www.eatworms.org.uk/cacti/ for nbar and saa monitoring with cacti)
There is also an inncomplete script on http://cosi-nms.sourceforge.net/alpha-progs.html which is a nice start building your own script.
If you find something another good solution I like to hear from it.
4004
