More PBR questions...
I have a 2801 with a T1 on S 0/2/0 and DSL PPPoE on FE 0/1/0. I can set default route to either and both work fine. I'm trying to force http/https traffic just to the DSL connection.
When I monitor the connections in the SDM, and start a big download via http, I can see the TI link bandwidth go up, while the DSL doesn't...
If I debug ip policy I get:
000960: Aug 14 16:02:16.349 MDT: IP: route map toDSL, item 10, permit
000961: Aug 14 16:02:16.369 MDT: IP: route map toDSL, item 10, permit
000962: Aug 14 16:02:16.373 MDT: IP: route map toDSL, item 10, permit
000963: Aug 14 16:02:16.389 MDT: IP: route map toDSL, item 10, permit
How can I determine if the policy is indeed sending http through the correct link?
Re: More PBR questions...
Using PBR you're setting the way traffic leaves your network (i.e. from client to server). Return traffic will follow path what your upstream routers think will lead to your client. So if packets leave with unmodified IP address that routed from your provider over your T1 interface, then traffic from server will return over T1 link.
That makes sense.
So how do I ensure that packets return via DSL link?
Gold
You need to source them with addresses that are provided to you from the ISP that runs the DSL connection.
It is sorta strange that you could even send packets out the DSL sourced with ip's routed to you via your t1. The ISP should detect that IP address spoofing and drop your traffic.
You will need to nat the addresses as the leave the DSL to a range that is routed to the DSL connection.
I am assuming that you do not have your own block of ip's that is being routed via the DSL and the T1. Get a little harder then.
The only other way to do this is if same ISP provides both the T1 and the DSL. Some offer this kind of service as part of a package normally sold as a backup connection. Can't hurt to ask them.
FE 0/0, the inside interface, is natted "inside".
FE 0/1, the DSL, is natted "outside".
The connection to the DSL is PPPoE, so both sides of the PPPoE "tunnel" are /32.
How do I nat the PPPoE interface Dialer1 to use the addresses from that assigned PPPoE connection?
Here is the config, edited for brevity:
router#show run
Building configuration...
Current configuration : 4513 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
boot-start-marker
boot system flash c2801-ipbasek9-mz.124-8.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret xxx
no aaa new-model
resource policy
clock timezone MDT -7
clock summer-time MDT date Apr 6 2006 2:00 Oct 26 2006 2:00
no ip source-route
no ip cef
ip tcp synwait-time 10
no ip bootp server
interface FastEthernet0/0 (Inside interface)
ip address xxx.xxx.xxx.xxx 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip policy route-map toDSL
no ip mroute-cache
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1 (DSL connection via Qwest)
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no mop enabled
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Serial0/2/0
ip address xxx.xxx.xxx.xxx 255.255.255.252 (T1 connection via XO, default route)
interface Vlan1
no ip address
ip mtu 1492
interface Dialer1
description Qwest DSL
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username user@qwest.net password 7 password
no ip classless
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx (S 0/2/0, T1 default route)
no ip http server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map int1 interface Dialer1 overload
logging trap debugging
access-list 100 permit ip host xxx.xxx.xxx.xxx any (FE 0/0, inside interface)
access-list 111 permit tcp any any eq www
no cdp run
route-map toDSL permit 10
match ip address 111
match interface Dialer1
route-map int1 permit 10
match ip address 100
control-plane
end
Your access-list 100 matches only FE0/0 address, so only traffic sources from IP of FE 0/0 (literally single IP that configured on FE 0/0) will be NAT'ed to Dialer1 address, however all PC behind your router will not be NAT'ed. I'd allow everything that goes out of that interface to be NAT'ed.
This appears the only reason why your HTTP traffic returns over main line. Change access-list 100 appropriately and all should work.
So you need to ensure that packets leave with source IP that would lead return traffic back over the same interface. One possibility is to apply NAT to such client connections, so the source of the packets is modified to become WAN IP of your DSL link.
Silver
I found you applied correct access-list 111, which is configured at the route-map. However, you do not configure the next-hop for the PBR. Your route-map should be as below :
set interface Dialer1
Please try it and advise the result.
Check below for more details:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_configuration_guide_chapter09186a00800ca590.html
Hope this helps.
143
