Community Member
More that 8 routed SVI:s
We have a few catalyst 3550/3560/3750 and as far as I know they only support 8 routed SVI:s each.
Although it is possible to create more than 8 SVI:s, it is not supported by Cisco. I would like to reduce these switches to two or three, thus increasing the number of SVI:s om each switch. What other Catalyst switch supports more than 8 routed SVI:s? I know that 4500 series and 6500 series catalysts will do the job, but do Cisco have other L3 switches?
Re: More that 8 routed SVI:s
Hi Mattias,
As far as I know Catalyst switch models 3550, 3560, 3750, Catalyst 4500/4000 Series with Sup II+ are the only ones supporting layer 3 switching, excluding Cat 6000/6500
http://www.cisco.com/en/US/tech/tk389/tk815/tk857/tsd_technology_support_sub-protocol_home.html
Lejoe
Hi Mattias,
I dont think there is limit on the number of SVIs that can be configured, however excessively doing so could affect performance.
http://supportwiki.cisco.com/ViewWiki/index.php/How_many_Switch_virtual_interfaces_or_routed_ports_can_be_configured_in_a_Catalyst_3550_switch
Lejoe
Community Member
Well, the size of the TCAM is finite, and to many SVI:s will indeed affect perfomance.
So, to summarize:
We need to use Cat 4500 or 6500 to use more than 8 routed SVI:s and still have a supported configuration.
Is this correct?
Hall of Fame Super Bronze
Mattias,
Can you provide a link where it states the limit is 8?
Based on the 3560 documentation:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_46_se/configuration/guide/swiprout.html
A Layer 3 switch can have an IP address assigned to each routed port and SVI. The number of routed ports and SVIs that you can configure is not limited by software. However, the interrelationship between this number and the number and volume of features being implemented might have an impact on CPU utilization because of hardware limitations. To optimize system memory for routing, use the sdm prefer routing global configuration command.
HTH,
__
Edison.
Community Member
Hi ediortiz,
thanks for your reply!
This is what the sdm template says for Catalyst 3550/3560/3750 and I think this can be found elsewhere in the Cisco documentation.
Here is one link:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a00801e7bb9.shtml
And here is the output from one c3550:
ro01-ipa#sh sdm prefer
The current template is the default template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1K VLANs.
number of unicast mac addresses: 5K
number of igmp groups: 1K
number of qos aces: 1K
number of security aces: 1K
number of unicast routes: 8K
number of multicast routes: 1K
ro01-ipa#
I've read somewhere on the net (can't remember the forum) that using more than 8 SVI:s (or routed ports) is not support on these Catalysts.
I might be wrong, but I need to know what configuration is supported by Cisco.
Mattias,
That's a very good observation. I've searched internally and I can't find a conclusive answer to this limitation.
What I've found is a suggestion to verify your CPU performance as soon as you go over the 8 routed interfaces limit. If the CPU maintains low %, then you should be fine.
With that said, you can create more than 8 routed ports in the router w/o receiving an error in the CLI. I was able to create 15 routed ports in the lab w/o seeing any performing issue nor receiving an error in the CLI.
HTH,
__
Edison.
Please rate helpful posts
275
