Moving T1 from 1720 to 2811 with existing T1
Serial0/3/0 works fine. No matter what I try I cannot get Serial0/1/0 to work. I have tried it in different slots, I have removed Serial0/2/0, I have mostly just gotten confused. I am sure this is something simple, just not for me. Pointing me in the right direction would be most appreciated.
I have this config in 1720:
interface Serial0
description connection to internet
no ip address
encapsulation frame-relay IETF
no ip route-cache
no ip mroute-cache
service-module t1 timeslots 1-24
service-module t1 remote-alarm-enable
frame-relay lmi-type ansi
interface Serial0.1 point-to-point
ip address 64.xxx.xx.xxx 255.255.255.252
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 737
interface FastEthernet0
ip address 69.xx.xx.x 255.255.255.248
speed auto
full-duplex
ip classless
ip route 0.0.0.0 0.0.0.0 64.xxx.xx.xxx
no ip http server
I have this config in the 2811:
card type t1 0 1
card type t1 0 3
controller T1 0/1/0
framing esf
fdl ansi
clock source internal
line code b8zs
channel-group 0 timeslots 1-24
controller T1 0/3/0
framing esf
fdl ansi
linecode b8zs
interface Serial0/1/0:0
encapsulation ppp
no ip route-cache cef
no ip route-cache
interface Serial0/3/0:0
ip address 66.xxx.xx.xx 255.255.255.248
encapsulation ppp
1 ACCEPTED SOLUTION
Gold
Re: Moving T1 from 1720 to 2811 with existing T1
Are not getting the interface to come up at all or is it that it just does not work.
Your frame relay configuration may or may not work depending if frame inverse arp is enable on the far end.
I would use the frame relay map statement on under the interface and map the far address to dlci 737.
You best bet since it works on the 1700 and is a little less confusing is to use a subinterface on the 2800 and remove the ip from the main interface. You should be able to copy the subinterface exactly as it is and only change the serial0.1 to s0/1/0:0.1
Hi Scot
Do throw more clarity on what you are trying to do over..
Are you trying to install the serial module taken out from 1720 onto 2811 ?
regds
No, the 1720 TSU stays with the box. The 2811 has two VWIC2-1MFT-T1/E1 (both will be data only, with possible future voice). I am trying to get the T1 that is attached to the 1720 working in the 2811. I have an existing T1 in the 2811 already working on the second VWIC2-1MFT-T1/E1. I just cannot seem to get the T1 from the 1720 working in the 2811 even if I turn off the second VWIC2-1MFT-T1/E1 (from searching the web, I thought it might be a clock issue). I have also moved the VWIC to a different slot, because I read that Slot0 can be finicky with VWICs if you do not use voice.
Thanks.
Ooops. Re-reading my post and realized I copied s/0/3/0 twice instead of posting s0/1/0 correctly.
Serial0/1/0 should read
no ip route cache
What about version?
I have had the WIC 1T-DSU units that only V2 works in the 2800
Version of IOS? 12.4
I already have one T1 working in the 2811 so not sure if version is an issue. It just seems to be the T1 that is being moved from the 1720 that does not work.
Can you paste the output of show version and show diag taken from your router here ??
Also have you mirrored the same config of working T1 onto the second T1 ??
regds
sh run sh diag attached.
I cannot mirror the exact config from the 1720 to the 2811 because they have different IOS versions and the WAN cards are different.
Am I missing something in the new config?
Here is the interface info from the 1720:
interface Serial0
no ip address
no ip route-cache
no ip mroute-cache
no ip route-cache
no ip mroute-cache
speed auto
full-duplex
ip classless
no ip http server
Gold
It comes up, it just does not play nice with the ppp on s0/3/0. The internal support person will only give me partial info on the circuit and the current config on the 1720 so I am guessing at some of the settings. I will try the subinterface and let you know. Thanks.
tdrais - Your solution was definately part of making this work. Adding the subinterface made troubleshooting easier. The frame apparently has horrible clocking. I changed the clock to s0/3/0 and set the frame to clock internal. Both interfaces now play nicely.
148
