10-02-2013 02:59 PM - edited 03-04-2019 09:12 PM
Hi Experts,
I was tasked on configuring our MPLS network from sitea-to-siteb.
Thing is, I know that MPLS is configured on the SP network. So I'll only be configuring the routing protocol from CE-to-PE.
In addition, I only need to configure the CE router and the networks you need to advertize.
One thing that struck me is that there is this QoS.
This seem to be the roadblock to my complete understanding of my task.
I have this QoS details:
Queuing Methodology: QUEUING METHODOLOGY A
QVUR: 0
QOS Template: Priority 1 = 0, Priority 2 = 5, Priority 3 = 0, Priority 4 = 95
I understand basic QoS but I can't seem to fit this details together.
Any info about how to use this QoS details is deeply appreciated.
Cheers,
novice
10-02-2013 06:41 PM
Hi Novice,
Is that the queueing model used on PE? Did provider give you the queuing methodology a? This looks like 2 queue modle, 5% for queue 2 and rest for queue 4. Can you get more detail on the queueing methodology, like what DSCP will be mapped to which EXP bit, which EXP bit will be used for which queue?
HTH,
Lei Tian
10-02-2013 08:03 PM
Thank you for the response Lei.
I may need to coordinate other information with the provider. This is only the start of the project actually.
So far that is the information I have right now. I'll keep you posted.
If I may, have your implemented MPLS with QoS? May I ask for some tips and best practices?
Sample config would also be great.
Thank you!
10-03-2013 03:51 AM
Hi Jemel,
Lei is right that you are clearly missing some information at this point of time. The only reference on the web I could find for QVUR was 'Qwest VoIP Usage Ratio' but couldn't find out what their template priorities match up to (e.g. Voice, Best Effort etc).
With regards to MPLS with QoS. I think I understood from your post that you will be in charge of configuring the CE, in which case you won't be using MPLS Experimental Bits for QoS - that will be the job of your service provider to remark your DSCP tagged packets with the relevant MPLS EXP bits. Because of this, it shouldn't be anything you are not familiar with if you are happy with normal DSCP based WAN QoS.
10-03-2013 04:02 AM
Hi Jemel,
As Jamie said, you need to configure your CE router. So, you need to make sure your QoS model matches the SP QoS model. Sometime, you need to reclassify the packet when it leaves to SP. You want check with SP which DSCP value will map to which queue in their queueing model, so you can config accordingly. You might also want to confirm with SP whether they will keep your DSCP value when packet leaves PE.
HTH,
Lei Tian
10-03-2013 01:04 PM
Jamie, Lei,
That's some information. Well then off to configuring CE and coordinating with the ISP with regard to QoS.
Thank you guys! Much appreciated.
Novice
10-21-2013 05:04 PM
Hi everyone,
We've decided to have the QoS configurations on default settings for now.
That leaves me to configure the CE's MPLS connection to other sites.
Which is pretty much complete.
May I ask if there are other security concerns that I should be configuring?
CE Router should be accesible from the internet.
Is there anything else that I should be considering?
Thank you!
Hope to hear from you soon.
10-21-2013 06:28 PM
Hi Jemel,
MPLS VPN service has logical data separation, so there is some sort security build in for this service. Like other customer will not be able to access your data even it shares same physical wire with your data. However, if you dont trust the provider, then you should do data encryption on the private WAN links too. Lot customers are doing data encryption on private WAN links, technology like GET VPN or FlexVPN is prefect for providing ipsec encryption while still keep the any to any type of communication from MPLS.
HTH,
Lei Tian
10-21-2013 06:36 PM
Hi Lei,
Does this GETVPN or FLEXVPN affect any service?
Like are we expecting some degrade in network performance due to processing of packets?
Is CPU utilization greatly affected by these type of encryption?
In addition, I would like to access this device from the internet.
Is there any other consideration that I need to be aware of? - aside from defining the Public IP Address that supposed to have access to the define and put it in access-class of the line VTY?
Thank you.
Jem
10-22-2013 04:22 AM
It will increase the CPU utilization, but will not affect your existing services, unless you are really pushing the limit. Nothing special needs to be considered for internet access, use AAA instead of local or enable for authentication.
HTH,
Lei Tian
10-22-2013 12:50 PM
Thank you Lei for sharing your ideas.
Much appreciated.
Novice
10-22-2013 06:42 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You'll need to obtain clarification on your MPLS provider's QoS model. In general, you want to provide QoS to manage any logical or physical congestion as you egress to the MPLS cloud, and you'll want to use your MPLS provider's QoS to manage any congestion as traffic leaves the MPLS cloud. You may mimic the provider's QoS model for your egress to their cloud, but you don't always have to.
10-22-2013 12:49 PM
Hi Joseph,
Thank you for the information.
What if we have the default FIFO, would it be of better setup if we have something different than the MPLS provider would give us? Something like LLQ maybe?
Novice
10-22-2013 05:31 PM
Disclaimer
Posting
Whether you there's any advantage of having QoS different from what your MPLS provider has, depends on what your MPLS provider supports and the QoS capabilities of your equipment. Often MPLS provider can also support LLQ, some providers charge extra for that though.
The only advantage of default FIFO (especially single queue FIFO) is its low resource overhead.
