MPLS LAB
I am a attempting the setup a MPLS lab.I am currently using the IOS c2600-advipservicesk9-mz.124-10.bin. It does not give me any options to setup MPLS under the config int or the config-if. Does anyone know a IOS that does have MPLS for the 2621 router I am using?
Hall of Fame Super Bronze
Re: MPLS LAB
You are facing a hardware limitation, not a software limitation.
The 2621XM does not support full-blown MPLS, just VRF-Lite.
If you want to configure mpls ip, you need to upgrade your hardware. In the 2600 family, 2650XM or better.
HTH,
__
Edison.
Please rate helpful posts
Re: MPLS LAB
I found this IOS and it seems to work for the 2621 for MPLS. c2600-adventerprisek9-mz.123-26.bin
Silver
Re: MPLS LAB
Hi Edison,
I agree with you but if see the following link they say the 2621XM support MPLS. Does that MPLS is referring to VRF-lite
http://www.cisco.com/en/US/products/hw/routers/ps259/prod_bulletin09186a0080161082.html
Hall of Fame Super Silver
Re: MPLS LAB
Hello Edison,
a 2621XM should be able to support MPLS as far as I know the real trouble is with the old 26xy that are not able to do it.
The hardware limitations should be there
Hope to help
Giuseppe
Re: MPLS LAB
Vishwamurti and Giuseppe,
My information came from internal sources and the Cisco Feature Navigator.
If you take a look at the Cisco Feature Navigator, there isn't support for MPLS under 2621XM while there is support for MPLS under 2650XM.
While the Cisco Feature Navigator has been wrong in the past, I found strange the OP did not have the MPLS features under the software he was running which indicated a hardware limitation as stated by the Cisco Feature Navigator.
It seems I was wrong and with that hardware - it works under Advanced Enterprise Services - but he had to go to an old train to get that feature, strange ...
__
Edison.
185
