Mpls Null label for default route
I want to know that why mpls generates a null label for the default route ?
what's the logic behind generating a null label ?
Thanks & Regards,
Rahul
Hi Rahul, You may get your
Hi Rahul,
You may get your answer in below post. Bydefault it does not allocate label for default route but if you have requirement you can enable it with command "mpls ip default-route"
http://ieoc.com/forums/p/3368/24902.aspx
Akash
 Thanks for the Reply I
I already know this thing that it is the default behavior that mpls generates a null label for default Routes.
But I want to know that whats the logic behind this of not generating the label i.e. is their any problem in Routing protocol or their will be any other problem in our network by using label for default route.
Rahul Chhabra
147
