MPLS on 1700, ver 12.4
I cannot configure MPLS on a 1700 router. Version 12.4!!
I type in
IP CEF then go under each interface either s0/0 or e0/0 type
type in MPLS IP
it says command unrecognized. What am I doing wrong ?
I can't configure it from both Priveledged or global mode
Please help.
Hall of Fame Super Bronze
Re: MPLS on 1700, ver 12.4
MPLS is not supported under the 1700 Router. You need an 1805/1841/1861 with 12.4T Release for MPLS support on those entry level routers.
HTH,
__
Edison.
Are these the ONLY routers that support it 1805/1841/1861 with 12.4 ?? or there are other ones ?
Cisco has a big product line so I won't list every single router that support MPLS.
Best course of action for you is to check this website: http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp and Select "Search By Feature".
The intended feature is MPLS.
HTH,
__
Edison.
193
