ā09-01-2012 11:49 AM - edited ā03-04-2019 05:27 PM
Good day all!
I have been assigned the task of configuring a 3945 router for sip circuit.
The service provider gave me the following info:
Subnet: s.s.s.s
Gateway: t.t.t.t
NetMask: f.f.f.f
Usables: c.c.c.c thru .c
DNS: g.g.g.g And .g
E1: b.b.b.b
E2: x.x.x.x
Where am I supposed to put this config? On the bonded serial link? Do I need more info?
Thanks!
ā09-01-2012 05:22 PM
Hi, i think its in the serial link connected to your ISP interface, if there is no device given by the ISP that should be linking your router to the the ISP interface line.
If the solution is different then my opinion, thank you to let know plz, i just start about Cisco World.
Posted by WebUser OD Weed from Cisco Support Community App
ā09-02-2012 02:38 PM
Where is "e1" and "e2" supposed to be defined?
Isn't the provider supposed to supply framing and clocking info as well?
