07-08-2010 01:13 AM - edited 03-04-2019 09:00 AM
Hi...
Can any one post MPLS scenario config at service provider.
Like.... HO(Any Routing protocol/BGP)-----------SP MPLS---------Branch(Routing protocol /static route)
Thanx......
Solved! Go to Solution.
07-08-2010 08:44 AM
Hi Arjun
Please refer the below link where you will get an idea of MPLS SP.
https://supportforums.cisco.com/docs/DOC-11383
Chetan Kumar
07-08-2010 02:55 AM
07-08-2010 08:44 AM
Hi Arjun
Chetan Kumar
07-11-2010 09:15 PM
hello ,
good share.
07-12-2010 02:37 AM
Hi Chetan...........
That's it........ what I want!!!!!!!!!!!!!!!!!!!!!!!!
Thanx a lot..
08-20-2010 01:18 AM
Hi chetan..
Can u tell what are the diagnostic command in MPLS.
I creat a Lab scenario as per your blog like.. (RIP)Cust_A1-------------PE_1....P-CORE...PE_2---------------Cust_A2(RIP)
I have learn RIP routes PE_1 and PE_2 form respective cust 1 & 2 but i am not able to ping form cust 1 to cust 2 and vice-versa.
Kindly suggest.....
Thanx............
