05-07-2014 02:29 PM - edited 03-04-2019 10:56 PM
I have an already existing 6509 that is going to provide the entire MPLS routing table via route reflector to a new 6509. Here are the relevant configs:
EXISTING 6509 (Router A)
interface Loopback0
ip address 10.255.2.2 255.255.255.255
end
router bgp 23532
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 10.255.2.3 remote-as 23532
neighbor 10.255.2.3 update-source Loopback0
address-family ipv4 mdt
neighbor 10.255.2.3 activate
neighbor 10.255.2.3 send-community extended
neighbor 10.255.2.3 route-reflector-client
neighbor 10.255.2.3 soft-reconfiguration inbound
exit-address-family
address-family vpnv4
neighbor 10.255.2.3 next-hop-self
bgp redistribute-internal
exit-address-family
address-family ipv4 vrf CustomerA
redistribute connected
redistribute static
no synchronization
exit-address-family
DAL-COLO-6509-1#show mpls ldp neighbor 10.255.2.3
Peer LDP Ident: 10.255.2.3:0; Local LDP Ident 10.255.2.2:0
TCP connection: 10.255.2.3.16271 - 10.255.2.2.646
State: Oper; Msgs sent/rcvd: 647/646; Downstream
Up time: 06:07:30
LDP discovery sources:
Vlan65, Src IP addr: X.X.X.69
Addresses bound to peer LDP Ident:
10.255.2.3 X.X.X.69 X.X.X.254 10.10.1.31
DAL-COLO-6509-1#show mpls forwarding-table 10.255.2.3 detail
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or Tunnel Id Switched interface
257 Pop Label 10.255.2.3/32 22272 Vl65 X.X.X.69
MAC/Encaps=14/14, MRU=1584, Label Stack{}
001CB14458000009B6A4B8008847
No output feature configured
DAL-COLO-6509-1#show mpls ldp bindings 10.255.2.3 32
lib entry: 10.255.2.3/32, rev 4933
local binding: label: 257
remote binding: lsr: 10.255.2.1:0, label: 131
remote binding: lsr: 10.255.2.3:0, label: imp-null
DAL-COLO-6509-1#traceroute 10.255.2.3
Tracing the route to 10.255.2.3
1 69-69.netblk-66-60-69.yada.net (X.X.X.69) 0 msec * 0 msec
DAL-COLO-6509-1#
New 6509 (Router B)
router bgp 23532
neighbor 10.255.2.2 remote-as 23532
neighbor 10.255.2.2 update-source Loopback0
neighbor 10.255.2.2 activate
neighbor 10.255.2.2 send-community both
neighbor 10.255.2.2 soft-reconfiguration inbound
exit-address-family
neighbor 10.255.2.2 next-hop-self
exit-address-family
redistribute static
no synchronization
exit-address-family
Br26-COLO-6509-1#show mpls ldp neighbor 10.255.2.2
Peer LDP Ident: 10.255.2.2:0; Local LDP Ident 10.255.2.3:0
TCP connection: 10.255.2.2.646 - 10.255.2.3.16271
State: Oper; Msgs sent/rcvd: 657/657; Downstream
Up time: 06:16:40
Vlan65, Src IP addr: X.X.X.70
10.255.2.2 X.X.X.10 X.X.X.14 X.X.X.5
66.60.70.18 66.60.75.252 66.60.72.65 66.60.75.81
10.10.1.40 66.60.70.17 X.X.X.17 66.60.73.161
X.X.X.70
Br26-COLO-6509-1#show mpls forwarding-table 10.255.2.2 detail
40 Pop Label 10.255.2.2/32 0 Vl65 X.X.X.70
0009B6A4B800001CB14458008847
Br26-COLO-6509-1#show mpls ldp bindings 10.255.2.2 32
lib entry: 10.255.2.2/32, rev 40
local binding: label: 40
remote binding: lsr: 10.10.1.30:0, label: 29
remote binding: lsr: 10.255.2.2:0, label: imp-null
Br26-COLO-6509-1#traceroute 10.255.2.2
Tracing the route to 10.255.2.2
1 70-69.netblk-66-60-69.yada.net (X.X.X.70) 0 msec * 0 msec
Br26-COLO-6509-1#
Im seeing label switching coming from the old switch (which has several MPLS VPN connections already). Im not seeing anything from the new switch. OSPF is the routing protocol between the interfaces, and shows to be working fine. LDP neighbor relationship seems to be good- just tagging isn’t occurring going back toward the old switch. Any suggestions?
Greg
05-08-2014 06:18 AM
Hello Greg,
because the two devices are directly connected, Penultimate Hop Popping (PHP) applies each device advertise its own loopback in LDP with an implicit null (should be label 3) and the action is POP label and so the label stack is empty and the packet is sent as a native IP packet as you see also in the traceroute.
What you see is normal behaviour.
You would need three devices connected in a row RA-RB-RC to see label propagation in action
Hope to help
Giuseppe
05-08-2014 07:16 AM
I need the MPLS VPN to come up, trade routes, and pass traffic. No matter what I do- it doesn't seem to fix this. That's the ultimate issue here. The new 6509 is acting as a Route Reflector Client getting it's routing table from the old switch.
Greg
05-08-2014 07:50 AM
Hello Greg,
I see your point.
post from new switch
show ip bgp vpnv4 all summary
only routes matching route targets of locally defined VRFs are actually imported
outside of BGP protocol you need
ip vrf CustomerA
route-distinguisher 1000:1
route-target import 1000:1
route-target export 1000:1
in both routers to build an MPLS VPN
Hope to help
Giuseppe
05-08-2014 08:01 AM
It's already there:
This is off the new switch:
ip vrf CustomerA
rd 23532:1
route-target export 23532:1001
route-target import 23532:1001
mdt default 239.232.255.0
Br26-COLO-6509-1#sh ip bgp vpnv4 all summary
BGP router identifier 10.255.2.3, local AS number 23532
BGP table version is 13652, main routing table version 13652
13 network entries using 1781 bytes of memory
13 path entries using 884 bytes of memory
7/4 BGP path/bestpath attribute entries using 1120 bytes of memory
6 BGP rrinfo entries using 144 bytes of memory
3 BGP extended community entries using 72 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 4001 total bytes of memory
BGP activity 3997/3970 prefixes, 9542/9515 paths, scan interval 15 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
10.255.2.2 4 23532 7853 3327 13652 0 0 00:02:16 11
Greg
Here is the show ip route statement for the VRF:
Br26-COLO-6509-1#sh ip route vrf CustomerA
Routing Table: CustomerA
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.105.46.0/24 is directly connected, Vlan217
C 10.253.0.9/32 is directly connected, Loopback2
05-08-2014 08:11 AM
Hello Greg,
all BGP routes are missing from vrf IP routing table
Can you post a sh version, sh module from new switch?
Only Sup7203B or better supports MPLS services in 6500 platform
Hope to help
Giuseppe
05-08-2014 08:13 AM
Yes- that is the problem we are trying to fix.
Br26-COLO-6509-1#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI13, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 11-Mar-14 04:53 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
Br26-COLO-6509-1 uptime is 1 day, 49 minutes
Uptime for this control processor is 1 day, 49 minutes
Time since Br26-COLO-6509-1 switched to active is 1 day, 48 minutes
System returned to ROM by reload at 09:20:45 CDT Wed May 7 2014 (SP by reload)
System restarted at 09:24:29 CDT Wed May 7 2014
System image file is "disk0:s72033-adventerprisek9_wan-mz.122-33.SXI13.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of memory.
Processor board ID SMG1125N74N
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
5 Virtual Ethernet interfaces
154 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Yes- we do have a Sup7303B in this switch.
05-12-2014 12:06 PM
Can you do this on the switch where the prefixes are not installed:
sh ip bgp vpnv4 vrf CustomerA
To see if you receive these via BGP
Alain
05-12-2014 02:24 PM
We are not receiving any routes/MPLS tags from the switch.
05-12-2014 02:25 PM
Br26-COLO-6509-1#sh ip bgp vpnv4 vrf CustomerA
BGP table version is 421, local router ID is 10.255.2.3
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 23532:1 (default for vrf CustomerA)
*> 10.105.46.0/24 0.0.0.0 0 32768 ?
*> 10.253.0.9/32 0.0.0.0 0 32768 ?
05-17-2014 10:06 AM
check your import/export policy on both routers
Could u disable default PE router behavior by configuring no bgp route target filter command under BGP to see all routes send through BGP vpnv4 table ,then use sh bgp vpn4 un all command to verify BGP routes.
Ashish
05-12-2014 11:57 AM
Anyone have any ideas?
