04-13-2006 07:24 AM - edited 03-03-2019 12:24 PM
Hi, we are frequently seeing the below error message in the routers log buffer -
CCP: ERROR - discarding pak for exess expansion! max = 5F2, actual = 886
I think this relates to a packet size problem for data that traverses a ISDN BRI interface which uses ppp encapsulation and is configured to use mppc for compression. Can anyone confirm or expand further on this error message as I don't fully understand the issue ?
Solved! Go to Solution.
04-19-2006 07:29 AM
You are running into a bug here. Check this Bug-Id:CSCsb91145
04-19-2006 07:29 AM
