02-06-2012 06:52 PM - edited 03-04-2019 03:09 PM
I've got very strange issue on two of my routers.
I've pretty straightforward tunnel configuration:
interface Tunnel0
ip address 10.5.4.66 255.255.255.252
ip mtu 1390
ip virtual-reassembly
ip tcp adjust-mss 1350
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 7 123
ip ospf network point-to-point
ip ospf cost 6580
load-interval 30
qos pre-classify
tunnel source x.y.z.a
tunnel destination z.x.a.b
tunnel mode ipsec ipv4
tunnel path-mtu-discovery
tunnel protection ipsec profile ospf-tunnel
All works fine but sometime cisco is changing this tunnel ip mtu to something else. Sometimes it shows in config, sometimes no.
We have a not good time to get idea who (or what) is changing.
SNMP is disabled. tacacs command accounting shows nothing. sh run shows that last config change was two days ago, but mtu was changed in last hour.
Like a ghost change our mtu
ios is
c870-advipservicesk9-mz.124-15.T12.bin
Solved! Go to Solution.
02-07-2012 03:02 AM
I have not personally experienced a similar behavior but theoretically, this could be caused by the tunnel path-mtu-discovery command. You may want to remove it and see if the MTU stops being automagically changed.
If this issue is determined to be indeed cause by the tunnel path-mtu-discovery then I suggest you put the command back, as it basically adapts your tunnel MTU to an appropriate size.
Best regards,
Peter
02-07-2012 03:02 AM
Best regards,
Peter
02-07-2012 07:31 AM
How do you know it is changing and is it changing incorrectly? As Peter mentioned, the MTU discovery feature tells the router to try to figure out the MTU on its own and use what it thinks is best.
02-07-2012 11:40 AM
Hi Jonothan,
Just check the output of "sh ip int". Also "sh ip ospf nei" shows me that some ospf neighbour can't make adjancency with my router.
