mtu size
CSCO10320953
You have a MTU of 512 bytes on serial link. Packet comes with 1024 bytes. What is true?
Router discards packet
Router fragments, if DF bit is not set
Router fragments and Router on other end of the link will reassemble
Destination on other end will reassemble
9 Replies 9
sourabhagarwal
Level 4
Level 4
Router discards packet should be the right one.
bvsnarayana03
Level 5
Level 5
Router fragemnts the pkt.
would u explain it sir
Hi, by default router fragment but there is an special bit at the frame that if is set it (DF=1, don't fragment) then the router discards the frame.
I agree with ISABEL,
The router will fragment the packet and will discard only if the Dont Fragment is set
Narayan
What is the difference of MTU listed under
"sh int fa0/0" and "sh ip int fa0/0"
Tx.
Jay
The "sh int fa 0/0" will show the interface information no matter it is configured w/ ip or not.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a7edb.html#wp1217547
The "sh IP int fa 0/0" will only show the interface info. if it is configured with IP.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_command_reference_chapter09186a008008802e.html#wp1028374
Hope this helps.
Jack - thanks.
You're welcome. :)
