Webcast-Catalyst9k
MTUnIPMTU
Hi Team,
What is the diddrence between MTU and IP MTU
PFA, in that MTU can be configured to
<1500-9216>  MTU size in bytes
IP MTU can be configured to
  <68-1500>  MTU (bytes)
and even for sub interface i could not able to change the MTU alone without changing MTU for physical interface.
% Interface GigabitEthernet0/0/3.6 does not support user settable mtu.
So please explain how ca we fix this.
Thanks & Regards,
Naveen
Super Bronze
Re: MTUnIPMTU
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
MTU applies to the physical interface.
IP MTU applies to IP packets.
It's possible you could have IP and something like (Novell's) IPX using the same interface and you might want to restrict the size of IP packets but not IPX packets.
Silver
MTUnIPMTU
Hi Naveen,
MTU
Each interface (based on technology) have its minimum and maximum supported size of PDU(protocol data unit), for example:
Ethernet  - 1500B
Token Ring - 4464B
ATM - 4470B
FDDI - 4352B
IP MTU
Sets the maximum size of IP packet.
Setting MTU is possible only on the physical interface, then it applies to all subinterfaces. After all, this makes sense.
Best regards,
Jan
MTUnIPMTU
HI Jan,
Thanks for your reply,
If MTU is 1500 bytes and if IP MTU is 1600 bytes, How it works.
Silver
MTUnIPMTU
Hi Naveen,
If this is the case, IP packet must be fragmented before sent by such interface. They need to be "cut" to more pieces of 1500B or less to make it over that link.
And even MTU of an Ethernet can be set to 1600 bytes right ?
Maximum ethernet MTU is 1500B.
If your interface supports giant frames or jumbo frames the payload can be as big as 9000B. But standard ethernet MTU is only 1500B.
Best regards,
Jan
MTUnIPMTU
111
