Webcast-Catalyst9k
multi-VRF for security
I?ve two different systems at one remote site.. I?m thinking of connecting the two systems by using one small router (Cisco 1800) which will connect both systems to different uplinks.
The question now can i use mulit-VRF feature to split the routing process between them to enhance the security coz one of those systems is critical? And can I use VRF with static routes?
Re: multi-VRF for security
yes this can be done but I'd check that your IOS supports this. VRF lite can be used with static routes. The below is an example of the sort of config you will require.
ip vrf TEST1
rd 11:11
ip vrf TEST2
rd 22:22
interface Serial1
description VRF TEST1
ip vrf forwarding TEST1
ip address xxxx
interface Serial2
description VRF TEST2
ip vrf forwarding TEST2
ip address xxxx
ip route xxxx xxxx xxxx vrf TEST1
ip route xxxx xxxx xxxx vrf TEST2
Thank you..
but why u are using (ip vrf forwarding TEST1
) commands ? why we need it here
260
