Multicast routing help needed..
My customer has a webcast server in one of their data cetners that needs to send multicasts out to all of their offices over the WAN. So far, I have been unable to get this to work. All of their locations connect into our MPLS and have their own VRF for the entire company. The source server as well as each site is on a different vlan. Below is the config i am using for each site, as well a mtrace from a client router. If you have any questions please let me know. Any information you can provide me on getting this to work will be appreciated.
422GEN139-rtr-2801#mtrace 10.2.19.205 10.254.190.130 239.192.19.76
Mtrace from 10.2.19.205 to 10.254.190.130 via group 239.192.19.76
From source (?) to destination (?)
Querying full reverse path...
0  10.254.190.130
-1  10.254.190.1 PIM/Static  [default]
-2  192.168.112.254 PIM Reached RP/Core [10.2.19.205/32]
//CPE device (site with server)
conf t
ip multicast-routing
interface Tunnel0
!! GRE_Tunnel_IP_ADDRESS
ip address 192.168.112.3 255.255.255.0
ip mtu 1400
ip pim sparse-mode
ip nhrp map 192.168.112.254 1.187.8.1                                   !! HUB_GRE_IP_ADDRESS / HUB_LOOPBACK_ADDRESS
ip nhrp network-id 100                                                 !! SAME FOR ALL ROUTERS
ip nhrp nhs 192.168.112.254                                       !! HUB_GRE_IP_ADDRESS
tunnel source 1.187.9.6                                                !! GRE_SOURCE_IP_ADDRESS
tunnel destination 1.187.8.1                                       !!GRE_DESTINATION_IP_ADDRESS
!! Configure PIM SPARSE MODE on LAN interface
interface FastEthernet0/0
ip address 10.254.244.1 255.255.255.0
ip pim sparse-mode
!! RP Address - HUB_LOOPBACK_INTERFACE.  ALL Multicast routers (including customer multicast routers) need to be configured same RP address. Check if they are using automatic RP assignment (AUTO RP or BSR). Here I assigned RP manually.
ip pim rp-address 1.187.8.1
!! RP address should be reachable through GRE tunnel for RPF check
ip mroute 1.187.8.1 255.255.255.255 Tunnel0
// HUB/RP router
conf t
interface Loopback0
ip address 1.187.8.1 255.255.255.255
ip pim sparse-mode
interface Tunnel0
ip address 192.168.112.254 255.255.255.0
ip mtu 1400
ip pim nbma-mode                                         !! PIM NBMA mode need to be configured on HUB
ip pim sparse-mode
ip nhrp map multicast dynamic
tunnel source 1.187.8.1
tunnel mode gre multipoint                        !! GRE multipoint mode is on HUB
!! Multicast Source address should be reachable through GRE tunnel for RPF check
ip mroute 10.254.244.100 255.255.255.255 192.168.112.3
//CPE device (END USER)
conf t
interface Tunnel0
ip address 192.168.112.6 255.255.255.0
ip mtu 1400
ip pim sparse-mode
tunnel source 1.187.8.24                                              !! GRE_SOURCE_IP_ADDRESS
interface FastEthernet0/0 .1
ip address 10.254.120.1 255.255.255.0
ip pim sparse-mode
interface FastEthernet0/0 .5
ip address 10.252.120.1 255.255.255.0
ip pim sparse-mode
interface FastEthernet0/0 .66
ip address 10.250.120.1 255.255.255.0
ip pim sparse-mode
292
