Multicast traffic
I'm trying to get some discussion on what amount of multicast traffic is too much, and how it can be contained or stopped on an interface. I'm posting the results of a 'sho int' from an internet facing router in my network.
GigabitEthernet0/1 is up, line protocol is up
Hardware is BCM1125 Internal MAC, address is 0017.9525.d251 (bia 0017.9525.d251)
Description: "to IPS TWTC cable 1"
Internet address is 216.54.146.1/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 11/255, rxload 4/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is RJ45
output flow-control is XON, input flow-control is XON
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 701
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 15970000 bits/sec, 6261 packets/sec
5 minute output rate 46324000 bits/sec, 7216 packets/sec
1585653950 packets input, 2159729978 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
1 input errors, 0 CRC, 0 frame, 1 overrun, 0 ignored
0 watchdog, 23675 multicast, 0 pause input
1901197083 packets output, 3193928813 bytes, 0 underruns
4 output errors, 0 collisions, 5 interface resets
4 lost carrier, 0 no carrier, 0 pause output
1 REPLY
Re: Multicast traffic
"Too Much Multicast" is one of those awkward questions. A quick look at the inbound there shows multicast as <1%. That's not much.
If it is a concern it might be better to try to capture some to see what the traffic actually is.
What routing protocol are you using? Remember OSPF, EIGRP , RIPv2 etc all use IPmulticast, along with numerous other protocols that use Multicast at either layer three or two.
223
